I bought this s15 last year with no wheels, no exhaust and no mods apart from a front mount, so pretty much completely stock. I have been learning to drift in it and have been modding it as required and this is how it currently stands;
2002 Nissan 200SX S15 [ADM] Odometer: 230,000km's <- chassis mileage, NOT engine km's (see below) Seating Capacity: 2 Mod Plate/Engineered: LK1, LA3, LA8 - 2 seater - Fixed back seat - Turbo system with front mount intercooler - 6 Point Rollcage with Braces & Padding
Engine SR20DET - 130,000km's - Compression tested 140-145psi across all 4cylinders 187RWKW (250HP) on 14psi Garret T28 bush bearing (replaced) Braided Turbo Oil & Water Lines Z32 Air Flow Meter Sard 550cc injectors with Sard Collars Walbro GSS342 Fuel Pump GFB Manual boost controller GKTech Rocker Arm Stoppers Apexi PowerFC with hand controller Koyo twin-core copper radiator Front Mount Intercooler 600 x 300 x 76mm Stainless Steel Exhaust Manifold Stainless Steel Intercooler Piping Stainless Steel Intake Pipe Stainless Steel 3" Catback Exhaust with HiFlow Cat Stainless Steel 3" Twin Pipes Stainless Steel 3" Dump Pipe Stainless Steel 3" Front Pipe Battery relocation to the boot with fuse & in-cabin isolation switch (2GA) New 480CCA Century Battery Neodymium Magnets on the oil filter and sump
Drivetrain Exedy Hyper Single Clutch rebuilt by Jim Berry with 4 puk Carbonic Button solid center and 3600lb pressure plate 6speed manual Tomei 2way diff (4.1 ratio) 6 bolt half shafts R33 Diff housing
Suspension/Handling/Steering Section Silkroad RM/A8 Base Height Adjustable Coilovers with camber tops and damper Adjust KKR Tie Rods & Rack Ends KKR Extra Lock Spacers D1 Caster Arms Section Silkroad Camber Arms Cusco Toe Arms Nolathane bushes throughout Cusco Strut Brace
Brakes New Rotors New QFM Brake Pads
Wheels/Tyre 18x9" +9 [R-Disk] WORK VS-KF's with Kumho ECSTA KU31 215/40/18 18x9.5" +26 [O-Disk] WORK VS-KF's with Federal 595 235/40/18
Interior Velo GP-90 seat (Brand New) on Bride Lowmax rail R33 GTR Series III Passenger Seat, red stitching Cusco Safety 21 6 point Rollcage with braces and padding Apexi Rev Speed Meter Apexi PowerFC Hand Controller AutoMeter Pro-Comp Boost Gauge Battery Isolation Switch Fire Extinguisher Central Locking Double Din 7" Touch Screen DVD/*everything* player with reverse Reversing Camera Sony 6" speakers InCar Camera Mount
Chassis Rolled/flared/pumped and repainted guards all round to fit epic wheels No damage to rails or undercarriage and no rust Paint is ok but needs a respray to be perfect
Things still to do Trust GReddy T518z 8cm Tomei Step 1 cams HPI intake manifold Electronic boost controller PAR Engineering 6sp dog internals
This post has been edited by GHOSTY: Jun 13 2011, 09:46 AM
ahh i see well im old school they must have changed the rules with that because back in the day i remember that you could only get away with a 4point. forget my noobness there lol.
Narh it's actually never had a bb turbo, I bought the car very cheap with little on it because I knew I'd just be changing it anyway. The main thing for me was a straight chassis with no rust etc.
isnt he talking about the s15 sr20det turbo itself? t28bb?
Yeah, but like I said I bought it cheap and it only came with a non-bb turbo because it had been changed by the previous owner to get the price down for me. Again not an issue because I'll be upgrading later anyway
Aren't 6 point cages illegal for road use? I thought you were only allowed half cages?
The engineer told me the cage cannot prevent you easily entering or exiting the vehicle (ie. why side intrusion bars are not legal in a street car), and if you have fixed back seats (which must be ADR Approved) the seating capacity must be reduced to 2 (which also requires a mod code) because it would prevent rear passengers from easily entering or exiting the vehicle. Cage padding around the drivers area must be 19mm thick, and 11mm thick in the non-occupied space.
QUOTE (JDM_R32 @ Jun 14 2011, 03:30 AM)
OT: Looks the goods man, love the cage padding.
Now you know what $50 worth of cable ties look like
