Ford Falcon EF
vltuff
  • vltuff
  • Budding User
Post #1 post 17th February 2011 - 05:25 PM
Engine: it currently has the standard motor in it but am in the process of putting an au xr6 tickford motor in it with a 5spd
Exhaust: 2and half inch with extractors
Suspension: cut springs atm but have low springs to be put in
Wheels: 15 inch rims
Modifications: au interior and engine and gearbox transplant
Stereo Audio / Visual: panasonic cd player with 6inch speakers
Estimated Power: 168kw from the tickford
this is my first which im doing up to drive any ideas on what to do to it or anything would be greatly appreciated cheers
 Ford Falcon Ef
 Ford Falcon Ef
 Ford Falcon Ef
 Ford Falcon Ef
 Ford Falcon Ef
 Ford Falcon Ef
  • Boost Network 25
  • PANEL WORX
    delete the vct dont run it and while ur at it cause its manual put a wade977b cam in it and crow adjustable cam will go pretty hard i got one but i got just a au bottom end i kept the ef headmines also auto with 2400 convertor
    vltuff
    yeah im not running the vct and yeah will do later on as this will be my car for while im on my l's thanks for the advice too
    derb
    ^^^ Pretty much that. Lose the VCT and get a cam that will run on the factory ecu. Good to see some e-series falcons about again.
    RIFFTOR
    Good work for the manual swap!
    I would be proud to have something like that (once it's done).
    slokey
    Get the springs un it ASAP.
    benji_xrt
    Nice project! Turbo that sucker!
    2wheeler837
    yeh e seriese rock, props for manual convertiong, if ur puttin heavy duty clutch reinforce the lug of the clutch peded brace and your fire wall. i pulled a hole in the firewall and broke the lug with a heavy duity. these respond great too cams if ya can afford get a chip 2
    cookie23
    burn it
    Nice Taxi.
    like where your goinf with this. with the right wheels and suspension, the EF/L's can look pretty tough. GL with it
    +1 for manual conversion too
    shiftmad
    i can feel a bon fire coming on
    Atomic_Nitro
    QUOTE (2wheeler837 @ Feb 18 2011, 03:44 PM) *
    I second that .... I don't own a ford but I know they pop walls :thumbsup: gonna be a nice ride when ya hit ya 'P' plates too
    Joins manual bandwagon - good idea while you've got the floor open.
    equipt85
    Had a mate with a el xr6 an it went better than i thought an just as quick as a vs 5L, got another with a au xr6 and hes had nothing but troubles with it....especially head gaskets an its only done 90 thousands k's
    TurboXR
    QUOTE (cookie23 @ Feb 18 2011, 04:21 PM) *
    burn it
    Fkn don't listen to wankers like this, should come up nice when your done..nothing wrong with ef/l-series!
    boost bogan
    love the e-series, miss mine :/
    cookie23
    QUOTE (TurboXR @ Feb 18 2011, 06:03 PM) *
    haha wateva @#$! just cause u drive a grandma spec lancer or ford
    TurboXR
    actually "champ", I drive a ba xr6t with 342rwkw...its on here in memebers rides posted up last year.
    rutager4152
    Get off boost and go to www.fordmods.com for starters :thumbsup: Then look up J3 chips, they're cheap and Ive seen some great results with them. And yeah like its been said a nice cam will really liven it up.
    E U R E K A M A D 9 4
    Looks like a decent project, choppies need to go though...
    [email protected]
    haha theres a sick as one in brissy do a lil bit of head work and put a 5 sp behind the standard motor and it will scream :thumbsup:
    PANEL WORX
    Oh yer and mines forsale to anyone want it
    vltuff
    thanks guys for the advice and yeah the springs will be swapped over as soon as the motor comes out
    vltuff
    thanks mate will do that and yeah im going to get a chip and a cam when im off my L's thanks
    PANEL WORX
    A 977b grind is like 145 exchange plus postage u dnt need a chip but it hunts idle abit plus a adjustable cam gear is 130 plus postage and chip is 190 and u got a pretty tuff coon barge
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
