1997 Nissan 200SX SX Sports Limited - QLD: Brisbane
b3n_rix
  • b3n_rix
Post #1 post 28th July 2012 - 08:06 PM
Engine:
1.5jz
Exhaust:
to be 4"
Suspension:
coil overs, toe arms, camber arms and castor rods and strut braces
Wheels:
stock
Modifications:
alloy rad
440cc injectors
t04z
custom turbo manifold
custom intake manifold
arp head studs
arp rod studs
heavy duty clutch
shimmed viscous
coilovers
camber arms
toe arms
castor rods
HIDs
custom engine and gear box mounts
custom wiring harness
dekota speedo and tacho boxs
jvc and pioneer stereo
alloy face plate for gauges and switches
remote start/push button start
044
surge tank
turbo smart boost controller
fmic
oil cooler + relocator
Stereo Audio / Visual:
jvc head deck
pioneer speakers
Estimated Power:
500-600hp
1997 Nissan 200sx Sx Sports Limited
  • Boost Network 0
  • gutless
    Certainly looks estimated.
    ajaay.
    600hp seems a bit rich ..
    Gerry Giraffe
    jo88
    is this road legal? i thought u couldnt put an older engine in a new car?.
    gutless
    QUOTE (jo88 @ Jul 29 2012, 02:53 PM) *
    Errrrrrr what?
    jo88
    well correct me if im wrong but arnt 1j's older than 1997? i thought the law was that u couldnt put a motor in a car that was newer than the engine. due to emission laws?
    Faun-
    hey nice photos man. who's 3210 did you take them on?.
    gutless
    QUOTE (jo88 @ Jul 29 2012, 03:05 PM) *
    Who said this engine was a 1J? And further more, At the simplest you could have just done a wiki search on toyota JZ engines and noted that 1Js were made till 2007 and that Chasers/etc. were made after 1997 etc. etc.. But really this engine isnt a 1J anyway.
    jo88
    QUOTE (gutless @ Jul 29 2012, 03:20 PM) *
    so how do they base the year of the engine in this case being a 1.5jz? he never stated in his details that it was a vvti 1jz in which case yes u are correct.
    gutless
    QUOTE (jo88 @ Jul 29 2012, 03:22 PM) *
    Its a 2JZ with a 1JZ head.
    b3n_rix
    no wonder some many people are avoiding here now, nothing people do is ever right for some.
    obviously people need to also read up on their engine/law knowledge, the block is a 2jz from a '94 supra, the head is a 92 soarer and the car is a '97 s14. It is 100% street legal.
    How??? well it is simple, you bring the emissions standards of the engine up to the car's standards, so it is using the s14 carbon canister, cat etc.
    I also find it amusing how people think that this won't see the numbers I want. especially when they no nothing else about the car, like what boost levels, what fuel or anything like that.
    b3n_rix
    obviously, if anyone knew what they were actually looking at they would also realise that the head is not a vvti just by looking at the covers
    ItsIHavok
    600hp on 440cc Injectors? Thats probably why they dont think you will see 600hp.
    Astra Boi
    Mad build dude have a fun with it
    bigmitch15
    I'm doing a 1J build in my S15 atm.
    I can't see you making that sort of power with 440's, but some bigger injectors and it's very much possible.
    And just wondering, but why did you put the 1JZ head on the 2JZ bottom end? It would have been better to keep the 2JZ head as well.
    gutless
    QUOTE (bigmitch15 @ Jul 29 2012, 06:24 PM) *
    Pray tell, why?
    bigmitch15
    A 2JZ head flows around 240cfm at .4" inlet and 155cfm at .4" ex where as a 1JZ head flows 215cfm at .4" inlet and 135cfm at .4" ex.
    So there for a 2JZ-GTE head would be a better option than a 1JZ head on the 3L bottom end.
    b3n_rix
    I didn't get the complete engine, nor is it a 2jz gTe,
    The other reason behind utilising the 1jz head is, it would allow me to reuse all my accessories.
    turnbullion89
    funkin haters
    Mongrel
    QUOTE (turnbullion89 @ Jul 29 2012, 11:10 PM) *
    funkin haters
    By haters you mean realists....
    you are not going to make 500hp+ on 6 x 440cc injectors....no matter what fuel you run.
    And the 37/01 emission that that 200sx is complied to are bullshit hard to match unless you are going to run lpg.
    You are definitely going to have troubles making them with a donkey old non VVTi JZ motor.
    There is a lot more to emissions than just carbon canisters and cat converters....most is to do with combustion chamber design/how complete the burn is and how quickly the O2 feed back can come online.
    If OP had of done some research, he would have realised that if he had of chosen a Pre 96 model, he wouldn't have any hoops to jump through at all. Not saying he won't be able to get it passed, but chances are if it does it would be on the sly.
    Your typical Boost cry-baby will respond with haters....a smart person would ignore the little digs and take the information on board and do something about it.
    Oh and nice ride by the way, looks like it should be a pretty clean swap when finishedand should make some descent power with some bigger injectors rolleyes.gif
    400DS
    QUOTE (ItsIHavok @ Jul 29 2012, 04:45 PM) *
    Who dat
    Cant wait to see it finished, need moar pics of the whole car.
    stephen16
    The hate is strong in this thread, I don't really understand, sure he has listed 440cc injectors but sure his planning to change them still if his aiming for 600hp, it's not like the injectors are a big job to change
    toranaslr
    Pictures, pictures EVERYWHERE.
    b3n_rix
    these are the ones through the build process. (in no particular order)
    and for all those that have argued about not getting to 600hp, this is true on 440s, I agree, however, that is an esitmated goal power figure, there for will be making the switch later on to ID 2000 and E85 when I plan on getting to that stage.
    Mongrel
    Go ID2000 and e85 straight off the bat, that and a descent three way cat converter and you'll pass emissions no worries. You'll have to double up on the 044's to make it all work though.
    Please tell me you are ditching the checker plate facia.
    514med
    Nice car good engine choice thumbs up from me
    turbo183
    I think you dropped a bit of coolant on the floor?
    disorders
    Ignore the haters. Mad ride!
