1983 Toyota Sprinter AE86
Malk
  • Malk
  • New User
Post #1 post 17th February 2012 - 01:33 AM
Engine:
JDM 4AGE
Exhaust:
2 1/4" No CAT Straight through + resonator + extractors
Suspension:
5kg/mm
Koni shocks
Wheels:
15x8 0 + 195/50 SSR Mesh Copies
Modifications:
Adjustable cam pulleys
Pod filter
Converted to electric radiator fan
Stiffer sway bars F/R
5(ish)KG/MM springs F/R
Strut Braces F/R
Koni Shocks F/R
15x8 0 SSR Mesh Copies
Cheap racing seats
Dildo shifter
-3" offset cheap ebay-special steering wheel
Short shift
Taken A/C off
Extractors + resonator + 2 1/4" pipe to straight through (not shown in any photos)
PLANS:
T Series diff with with LSD
272 cams
ITB's
Front lip
20mm spacer for the back wheels
Lower springs
Coilovers for the front
Cambertops (for moar stance)
Legit paint job
'Letterbox' grill
Stereo Audio / Visual:
Pioneer tape player with external 6 stacker cd player connect to two 6" speakers..
Estimated Power:
130hp
1983 Toyota Sprinter Ae86
  • Boost Network 10
  • gutless
    Cool Corolla.
    01BEN
    Has potential mate, I'd make the panel and paint priority one will make all the difference
    on_boost
    I may be wrong, but I think hes more concerned about going sidewayz
    TTS
    Post about having no catalytic converter along with your plates visible. Hello EPA...
    95_lude
    oh todd you and your sexy 86 <3
    Wraith
    QUOTE (TTS @ Feb 18 2012, 09:18 AM) *
    1983 = no cat needed if it didn't come with one from factory
    Riverside
    Unleaded, injected engine fitted, vehicle emissions must comply with what replacment engine required.
    You can put an engine from a VE commodore into an EH holden, it would also need all the emissions gear, including Cat convertor.
    Malk
    Haha.
    My dad is a well known VASS engineer so he wont let me do anything 'illegal' to it.
    The 1983 model of the corolla/sprinter (JDM and ADM) didnt come with Catalytic converters. All models after it I believe did come with it, although the rules state so long as its Pre-1986 it doesn't need it unless it came with it.
    And no I'm not going be sliding this car if at all, I'm getting a KE70 to do all the dirty work.
    I'd never be able to live with myself if I crashed it.
    01sik
    so, the owner of an 86 is buying a ke70 to slide?
    Malk
    QUOTE (01sik @ Feb 22 2012, 06:47 PM) *
    I guess so... ?
    Is there anything wrong in doing that?
