1993 Toyota Hilux SURF SSR Limited
lowbravo
  • lowbravo
  • Regular User
Post #1 post 15th January 2012 - 07:44 PM
Engine: 2.4lt efi turbo diesel
Exhaust: 2.5inch no muffers
Suspension: 3inch lift wound up torsion bars
Wheels: 15x8 black sunnies with 32inch bfgoodrich muddies
Modifications: bugeye wrx bonnet scoop(intercooler to come)
lift, tyres,beefed up fuelpump,9psi boost for now
Stereo Audio / Visual: keenwood cd/mp3
fusion carbon fibre 6inch splits running offits own fushion amp
fusion carbon fibre 6x9's boxed running off its own fusion amp
Estimated Power: stock plus a bit more
1993 Toyota Hilux Surf Ssr Limited
The path of the righteous man is beset on all sides by the iniquities of the selfish and the tyranny of evil men. Blessed is he, who in the name of charity and goodwill shepherds the weak through the valley of darkness, for he is truly his brother's keeper and the finder of lost children. And I will strike down upon thee with great vengeance and furious anger those who would attempt to poison and destroy my brothers. And you will know my name is the Lord when I lay my vengeance upon thee.
  • Boost Network 10
  • sdf4lyfe
    thats nice budd
    HarleyJace
    Looks good dude, how do you find it goes with no mufflers? I've got a 2 1/2" system on mine but appears to be after the dump back, but has a few mufflers. Goes well at 0.8 bar of boost, a little bit more would be better though.
    1%ER
    looks like fun. scoop looks good too.
    didn't even realise it was a subaru scoop.
    lowbravo
    goes really good without the mufflers
    its a bit loud sounds like a tough truck get mad turbo whistle at idle
    im gunna boost mine up to 12 psi soon
    trying to track down a intercooler and then im gunna run 15psi
    cheers guys
    lowbravo
    @harleyjace
    how did ya get ya boost to .8bar was it with a boost controller or did you do the washer trick in the wastegate accuator
    Gerry Giraffe
    Pretty tuff looking. Good work mate, i've always had a soft spot for these.
    HarleyJace
    QUOTE (lowbravo @ Jan 15 2012, 08:21 PM) *
    @harleyjace
    Just running 2 washer on the gate, works fine, never had an issue. You won't be able to run 15psi unless you can somehow bypass factory boost cut on these which is at 13psi.
    lowbravo
    well i might just aim for the 13psi then
    and find out if the ecu's are tuneable
    lowbravo
    Everything has a price kittyggirl;)
    reddahaydn
    looks great mate!!!!
