1987 Mazda RX-7 Series 4
87RX7
  • 87RX7
Post #1 post 25th July 2011 - 02:10 AM
Engine: 13b Bridgeport Turbo
Exhaust: HKS exhaust manifold, HKS wastegate with screamer pipe, 4inch off the turbo into a 3inch system with racing beat muffler.
Suspension: lowered heavy duty springs, adjustable GAB dampers, dba slotted front rotors, rebuilt 4 piston factory front calipers with bendix ulitmate pads, ferodo rear pads
Wheels: 19inch konya's deep dish 19 x 8 front with 225/35 kumho, rear 19 x 9 245/35 kumho
Modifications: pod filter, T66 turbo, custom polished intercooler piping, aftermarket bov, fmic, rebuilt engine, full bridgeport including larger exhaust porting, 2 new rotor housings,
2mm race apex seals, dowelled, lt8x ecu and hand controller, 4 bosch coils, custom 10mm race leads, ngk plugs, intank bosch fuel pump, custom surge tank, motor sport fuel pump, aftermarket fuel reg,
indy blue 1600cc injectors x 4, turbosmart eboost street, sport light flywheel, heavy duty clutch, cusco 1.5 way lsd
Stereo Audio / Visual: Its a bridgeport brap brap brap lol, inside momo race steering wheel, autometer sport comp rev counter with shift light, spec r boost gauge, monza fiberglass
bucket seat not in pics, mazspeed side bars, removed spare and tools, removed aircon, fan and heater core, removed audio system
Estimated Power: 397HP ATW hopefully should run 11s and 10s with micky thompsons and c16 race fuel, power to weight ratio smile.gif
This post has been edited by 87RX7: Jul 27 2011, 06:44 PM
1987 Mazda Rx-7 Series 4
  • Boost Network 33
  • gymjunkie22
    why need a massive wank tacho for
    tavomagoo
    Good power figure, wheels look good too.
    swoff
    is this "2LOUD" plates?
    TohmeZ
    QUOTE (tavomagoo @ Jul 25 2011, 07:03 AM) *
    are you joking?
    tezza078
    nice man i like it good job
    Modified
    Clean
    sin1325
    QUOTE (swoff @ Jul 25 2011, 07:07 AM) *
    looks like it.. runs 10's hey.. shit my car must run 9's then haha
    jonnytiv
    yeah..nice car, tidy smile.gif but not sure if it would even run low 11's.. id say u need at least 400 rwhp for those numbers..
    Buzdis
    nice smile.gif will run 11's easily with the right suspension setup... thats the hard part with IRS..
    397hp or 400 ? 3 hp isnt going to be the difference between 10's n 11's
    Touge_RBS13
    QUOTE (87RX7 @ Jul 25 2011, 02:10 AM) *
    397HP ATW
    QUOTE (jonnytiv @ Jul 25 2011, 10:29 AM) *
    87RX7
    QUOTE (gymjunkie22 @ Jul 25 2011, 05:48 AM) *
    factory tacho only reads to 8 and it can rev until 9 plus I want I shift light
    87RX7
    yeah 201OUD
    87RX7
    it should be capable of running 10s with the right grip running c16 race fuel, its limited now by pump fuel and only running 10psi
    IEATU
    Id get out there on the track and race it before you go claiming what it can and could do. With that amount of power it " SHOULD " run a mid - high 11 depending on the driver. Not with those rims and tyres but. Mph is a great indication on what your car is capable of. Untill you have some figures to show most people your hp figure is just a " wank factor ". Your car looks pretty clean. Alot cleaner then my s4 thats for sure ! best of luck with it all.
    Boostn32GTR
    dont under estimate a rotor.... they are freak motors.. may be unreliable as many have it, but damb they are quick with such little power as it may seem!!! id almost be happt to say a 400hp rotor is the equivalent to to 550hp piston... (yes hard to understand), but they rev and seem to deliver power alot more efficient to a piston motor (after all, a rotor engine consists of only 3 moving parts)
    skaterboi18
    ^^^ its true go research a rotor on youtube and then search like power figures and times 379hp or whatever would be low 11's
    Trebloc
    Nice S4 mate. What turbo you got? TO4Z or 35R?
    Shnydes
    Very cool.....I like it man.....best of luck with it bud
    turbobmw
    oh all the haters cry cry !!! this should run easy into the 11s with that power anyway nice rx7 . Treat it with respect and it will last a fair while
    87RX7
    QUOTE (Trebloc @ Jul 25 2011, 05:47 PM) *
    T66 .70 front housing and 1.0 rear housing on a hks exhaust manifold, hks wastegate with screamer pipe. I want to get a bigger turbo down the track.
    IEATU
    what workshop do u go 2 ?
    87RX7
    QUOTE (IEATU @ Jul 25 2011, 07:14 PM) *
    Mazfix at underwood ive found them to be real helpful and im happy with the tune, its awesome to drive and sounds phat
    ratta tat tat
    Yeah sweet as. Koys rims look great (they are koya aren't they? lol)
    You've made it pretty clear about using MT's for the drag strip, they'll hook up nice.
    13B NA is a mad enough motor. 397hp will be very fast indeed. One just needs to take a ride in the passenger seat to understand the g-force and sheer powerband of these engines. gl with it
    RXT07
    cameron92
    big rims need big brakes to fill the gaps./
    priceless
    fuck yeh bro!!! go the s4's!!!!!! this is so so so clean in person.. i was talkin too you a while ago at the springwood maccers after harrys wavey.gif i got the other white s4.. bport, same power and same turbo... lol minus the black strip.. tongue.gif hahaha top job!!!
    srhead
    Seen this car and raced it a few times, it's Fucken quick, my car was just tuned at 489hp and this rx7 is off it's tits, shop talking shit unless you are ready to put your money where your mouth is Boost losers
    IEATU
    QUOTE (srhead @ Jul 26 2011, 05:20 PM) *
    and what time and mph have you done ?
    toranaslr
    Thats a pretty damn nice s4, needs bigger brakes to fill the wheels but.
    87RX7
    QUOTE (toranaslr @ Jul 27 2011, 10:38 AM) *
    I have driven the car around lakeside 5 sessions of 5 laps brakes are awesome, no brake fade at all, no need for bigger brakes
    SSS300HP
    QUOTE (ratta tat tat @ Jul 25 2011, 11:04 PM) *
    And yes, I have been that person to ride in his RX7, and also I have driven it!! It is a very very quick car!!
    SSS300HP
    QUOTE (87RX7 @ Jul 27 2011, 10:47 PM) *
    I would recommend to put better brakes on it!! Green stuff EBC, good for the road and track!!
