Marko92mmm
nice mate!, good old traditional stock factory look , but id tint up some window tint |
sexywrxy23
I got the piping but was suggested from more then 5 people that Top mount is much better for the turbo! And the Sti badge is on its way from coming off but cbf, i didn't put it Top mount gives you better throttle response and less lag but being in the engine bay gets heat soaked so car sucks in warm air front mount has tiny bit of lag but gets you colder air. colder air is better for power gains. pretty dangerous to be running 21psi with no front mount and small exhaust. KAAAAAAAAAAAAAAAAAAABOOOOOOOOOOOOOOOM!!!! |
scottyg938
Hook up the front mount and get a new front bar and dont cut it up, then you will have a nice rex |
josh...ute...
wow this thing is going to explode lol 21psi with basically stock engine...CRAZY lol good luck |
ride29er
why hang the front mount if not hooked up?? |
SOOBZ
why hang the front mount if not hooked up?? 21psi on standard internals is insane, I thought anything over 14 was crazy in these things, hook up the cooler, ditch the wing and badges and drop it a few more inch's on coilovers and you will have one sweet rexy, prob drop the boost a good 10+ psi as well:P Mate, they run just over 1bar (14psi) standard. 15-16psi is fine with the standard engine as long as you have more air intake. My suggestion would certainly be hooking up the front mount, ditching the standrd intake with a pod or something similar. (in guard CAI) looks good but, lower it + de-badge the STI and your on the way...Drop the boost down to around 16psi, or you will lose your bottom end.. |
moe91
Thanks guys for the suggestions, i got stock front bar thats not chopped, just gta get it painted, btw How can i drop the boost on Standard chipped Ecu! They got no clue :S i was thinking if i can just chuck in Stock ecu from wreckers or something ? Well im gna work on tinting, lowering and first of all De-badge it |
ridin500
nice rexy mate |
