1973 Datsun 1200 - QLD: Brisbane
157OCK
  • 157OCK
Post #1 post 22nd February 2013 - 02:33 AM
G'day guys this is my mates F20C powered Datsun 1200 sedan
Full Dtp conversion from stock car to s2000 power in under 4 weeks Daniel did an amazing job..
73' 1200 50800miles 3rd owner
F20C S2000 AP1 engine and 6SPD transmission custom 1 3/4" stepped 1 7/8" extractors with merge collector 70mm exhaust
6" k&n filter with 3.5" intake pipe stock throttlebody. Custom aircon install
120y front struts
s13 front brakes
R31 skyline shortened diff LSD
Koni suspension
14" corona rims crown hub caps.
Toyo R888 semi slicks.
Original interior besides carpet
To keep the dash looking stealth Dtp was even able to get the factory dash speedo working he used a electronic signal converter to cable drive unit that operates the oem speedo then put the shift and oil lights inside the factory radio case.
Vtec @ 6000rpm &
189Rwhp 141rwkw
Next mod is safc2 install to lower vtec point and lean out the topend to hopefully crack 200whp
Check out Dtp Motorsport on Facebook for full build pics.
http://m.facebook.com/home.php?_rdr#!/..._user=671685873
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
1973 Datsun 1200
  • Boost Network 6
  • TTS
    Very clean and very cool but that is sacrilege!
    TurbostyleR
    I fricken love this. Excellent conversion and fantastic workmanship on it too.
    THE STIG
    V-tech yo... 10 points for a job well done. Poor little datto.
    matt_e_b81
    oh man that is sweet !
    McGnarly
    wow
    vk134
    That is truly the work of a great craftsman, what a clean looking datto, so many smart ideas
    The only thing the struck me as odd is the complex long air intake setup, VS swap battery to the other side and run short and direct airbox with CAI and no heat soak from the radiator
