15th August 2010 - 02:51 PM
Hey guys in having trouble with my silvia. It has an s14 sr20det running standard computer and im having some problems with it. Ive been told i need to reset the computer but am having trouble doing so... Ive tried disconnecting the battery and computer and left it for about 20hrs but it didnt change anything. CAN ANYONE PLEASE HELP?? This post has been edited by dionm: Aug 15 2010, 03:41 PM |
dionm
ok ill give it a go. |
DreamensioN
Not going over 2400rpm in an SR20DET is a faulty AFM. |
dionm
Not going over 2400rpm in an SR20DET is a faulty AFM. Engine not going over 3000rpm is ECU "safe mode". When you said you checked the AFM - checked what? The connection? Or the actual voltage it's reporting? Sounds like to me you have AFM sensor issues. well i checked it by having the car idling and then disconnecting the AFM and seeing if anything changed and when i removed it it just stalled. so u think it may be faulty?? whats the best way of checkin it?? cheers |
8700s14
Reseting the ecu is a straight forward process. Most disconnect the batter then press the brake pedal to deplete in remaining energy. |
vomit
its alomost like a 'boost cut' but wen i release the throttle i can still hear the flutter from the turbo. it happened the other night just after i got up it... Same thing happened with my SR awhile back, definatly sounds like its your AFM. Make sure all the pins are connecting properly and if no love just get a new AFM. |
DreamensioN
ill get a new AFM this week and try that hopefully that fixesit. is there a way of testing if my AFM is faulty?? After the engine is warmed up, at idle the sensor should read 0.8 - 1.5v. At 3000rpm it should read between 1.4 - 2.0v Attached pic... *Edit* Also further down it says this... Fail-safe Mode Detected items: Mass air flow sensor circuit Engine operating condition in fail-safe mode: Engine speed will not rise more than 2,400 rpm due to the fuel cut. |
dionm
After the engine is warmed up, at idle the sensor should read 0.8 - 1.5v. At 3000rpm it should read between 1.4 - 2.0v Attached pic... *Edit* Also further down it says this... Fail-safe Mode Detected items: Mass air flow sensor circuit Engine operating condition in fail-safe mode: Engine speed will not rise more than 2,400 rpm due to the fuel cut. thanx very much 4 your help mate. but how do i measure the volts?? also, just before 2400rpm it does hesitate like theres a fuel cut... |
DreamensioN
You need to use a voltmeter to measure the power. |
