Projecta Introduces The Idc25x: The Toughest And Most Reliable Dc/dc C
Tunde
  • Tunde
Post #1 post 1st August 2023 - 09:48 AM
Projecta Introduces the IDC25X: The Toughest and Most Reliable DC/DC Charger Ever Made
Why settle for anything less when you can have the toughest and most reliable DC/DC charger ever made?
Projecta, the automotive electrical equipment manufacturer, has released an enhanced version of its popular IDC25 DC/DC charger called the IDC25X. This new model aims to impress its loyal user group by withstanding higher temperatures and setting new industry standards for DC/DC chargers.
Projecta has raised the bar with the release of the IDC25X. This upgraded version of the popular IDC25 DC/DC charger is designed to handle even higher temperatures, making it ideal for under-bonnet applications. Its ability to perform in temperatures as high as 90 degrees Celsius sets it apart from its competitors. While other chargers may decrease their charge output under such extreme heat, the IDC25X provides a consistent 25A of charge at temperatures up to 75 degrees Celsius.
To ensure the IDC25X can withstand these high temperatures, Projecta has gone to great lengths to make it tough and reliable. The unit is fully potted with thermal epoxy resin, which draws heat away from the electronics and maintains a consistent charge output. Additionally, the charger is vibration- and shock-proof, meeting heavy-vehicle standards. This means that even the corrugated roads of the outback won’t pose a problem for the IDC25X.
Not only does the IDC25X excel in performance and durability, but it also offers superior protection against dust and water. Its IP68 and IP69K ratings ensure that it remains unaffected by the ingress of dust, water, and high-pressure water used in pressure-washing engine bays. This makes the IDC25X perfect for a variety of applications, including 4WD, RV, camping, boating, and more.
One of the standout features of the IDC25X is its versatility and compatibility with different battery types. Owners can charge AGM, GEL, WET, calcium, and lithium batteries using the customizable IDC25X. The charger supports pre-set charging modes and even offers automatic temperature compensation to protect valuable batteries. Additionally, the unit can be mounted at a distance from the battery thanks to its voltage drop compensation technology.
The IDC25X is not just a charger but also a solar controller. It prioritises solar charging by default and can automatically adjust to the alternator using Intelli-Charge when there’s insufficient sunlight available. This reduces power draw from the vehicle’s electrical system without the need for manual switching. The IDC25X also boasts improved solar power harnessing, accommodating solar inputs of up to 360W.
To make monitoring the IDC25X’s performance easy, Projecta has developed the Intellix-IQ smart display. This state-of-the-art display is supported by a user-friendly app compatible with smartphones and tablets. Owners can adjust battery charge profiles and set up future charging parameters to suit new batteries as they enter the market. The Intellix-IQ display incorporates LINbus technology, allowing multiple devices to be connected and controlled via a smart device or the display itself.
Lastly, to future-proof the IDC25X, Projecta will release software and firmware updates via Bluetooth. These updates can be installed in minutes and will allow owners to introduce new charging profiles and improve efficiency. Additional features, such as automatic lithium wake-up mode, will also be available in the future.
In conclusion, the new IDC25X from Projecta is the toughest and most reliable DC/DC charger ever made. It is designed to withstand extreme temperatures, vibrations, and shocks, making it perfect for various applications. Its smart features, such as the built-in solar controller and Intellix-IQ display, provide convenience and ease of use. With a five-year warranty and a price starting at $595.00, the IDC25X is a worthy investment for anyone in need of a reliable DC/DC charger.
The IDC25X is designed to withstand higher temperatures than its predecessor
It incorporates a super-efficient design that can perform in temperatures as high as 90 degrees Celsius
The unit provides a full 25A of charge at temperatures up to 75 degrees Celsius
It is fully potted with thermal epoxy resin and is vibration- and shock-proof
It has IP68 and IP69K ratings for protection against dust, water, and high-pressure water
The IDC25X is perfect for 4WD, RV, camping, boating, and other applications
It is compatible with multi-chemistry technology and offers automatic temperature compensation
The unit has a built-in solar controller and can accommodate solar inputs of up to 360W
The Intellix-IQ smart display allows for easy monitoring and customization
The IDC25X is backed by a five-year warranty and is priced at $595.00
Projecta has raised the bar with the release of the IDC25X, providing users with a charger that can withstand extreme temperatures, vibrations, and shocks. Its superior performance and durability, combined with its versatility and smart features, make it the perfect choice for a variety of applications. Backed by a five-year warranty, the IDC25X is a reliable and future-proof investment. So, why settle for anything less when you can have the toughest and most reliable DC/DC charger ever made?
