Xr6 Turbo Thread - Post your car
Page 2 of 5
kizzlemynizzle
My 2010 FG XR6T manual
pedders lowered springs and leafs
K&N pod filter
full exhaust
doso pipe
19x9.5 all round, wrapped in toyo's
force6alex
QUOTE (kizzlemynizzle @ Mar 19 2012, 06:49 PM) *
K&N pod filter
full exhaust
doso pipe
henz
QUOTE (TXR05 @ Mar 18 2012, 10:29 PM) *
thats not a FPV motor... good luck with your clutch too.
Yes it is. 2007 build mate. Clutch would be cactus if I drove it hard. But I can't decide weather to do a clutch or a 2-3speed.
QUOTE (force6alex @ Mar 19 2012, 06:17 PM) *
nice ute henz would be fun. seen your ute on falconxr6turbo.net sounnded pretty sweet with the dose pipe lol
Cheers mate.
Rancher
QUOTE (henz @ Mar 19 2012, 07:22 PM) *
Cheers mate.
Why did you change the tappet cover and coil pack cover then..?
henz
Fpv's come with a dark blue tapet cover. And the same coil cover.
Every turbo falcon built after 06/06 came with same motor as the FPVs (stronger rods, slightly better valve springs than ba turbos)
Fpv started the painted rocker cover, and have carried it through.
Feel free to confirm this on any ford forum, or even call ford spare parts.
Rancher
QUOTE (henz @ Mar 19 2012, 08:02 PM) *
I'm aware of whats done to the FPV motors. Yours has a red tappet cover, and the standard ford coil pack cover. Surely if you had an FPV motor in it, you'd have left the blue tappet cover, and FPV coil pack cover to show off.
Anchor
QUOTE (Rancher @ Mar 19 2012, 09:06 PM) *
You're missing his point. It's the same motor regardless of tappet cover colour. Whether it came in an XR6T or a Typhoon.
Rancher
Post #68
QUOTE (Anchor @ Mar 19 2012, 10:30 PM) *
So why feel the need to mention its an FPV motor..
henz
Post #69
Ahh because it's stronger buddy. I wouldn't push 360 out of a BA motor + stock valve springs.
Doesn't matter how it looks bonnets shut when I drive.
Anchor
Post #70
QUOTE (henz @ Mar 20 2012, 08:12 AM) *
I did. And bashed limiter @ powercruise for 4 days straight with stock oil pump. Tick tock.. oopsie.gif
And it's still going strong with the new owner. Currently up to 140,000 i think. Had a fresh head since the timing chain got caught up and jumped 4 teeth. New head, straight back on the dyno, same tune. Bores looked fresh, only small marks on pistons. Lucky. These things must have a safety if something like that happens. Car shut down straight away.
Also, don't use octane booster. Head and tops of pistons were orange....
Rancher
Post #71
So. What you're saying is. They're both the same motor. But they are different because the FPV motor is stronger. But they are the same with different tappet cover color and coil pack cover. But yours is the FPV motor with the standard red tappet cover and ford coil pack cover.
They are the same. But different. Ok. Makes sense.
Make up your minds. One of you is saying the FPV motor and XR6T motor is the same thing. The other is saying the FPV motor is stronger. Completely missing my question. If the FPV motor has BLUE tappet cover and FPV coil pack cover (And apparently, stronger rods/valves/valve springs). WHY have you put the RED tappet cover and FORD coil pack cover on the FPV motor? I don't need an explanation about why they are different but the same.
Edit: If the point you were trying to make is, they are both a 4LTR turbo I6. Duh. I'm well aware they are. I'm aware they are almost exactly the same, with a few different internal pieces, and more boost.
henz
Post #72
Fuckkk boost is still full of the same idiots.
Ok, after 06/06 EVERY turbo falcon (FPV and xr6t) came with the exact same motor. Same rods, same valve springs, every part. The xr6ts though, still have the red tapet cover. Fpv have continued the blue theme they started originally.
As for a BA making 360, can 450 if you want. But I personally wouldn't & didn't with my own BA.
Rancher
Post #73
QUOTE (henz @ Mar 20 2012, 09:16 AM) *
Yeah, you're one of them. Read what I'm saying you moron.
You have said you have an FPV motor. The picture you posted is clearly an XR6T motor. FPV have blue. Ford has red. Yours has red.
WTF? Don't spin this on me. ANSWER THE DAMN QUESTION.
FFS. I understand they are the same motor. Stop trying to tell me that. Answer my question. FPV has blue. YOU MOTOR, that is pictured above. Is red. Why.
julio_vasquez
Post #74
So you have an XR6t motor. Not FPV because you have the red tappet cover. Regardless if they are the same thing besides what they look like. Yours looks like an XR6t motor not FPV.
Post #75
Ahh the old retaliation of "fuck this site is full of xxxxx"
Just fess up. You said it has an FPV motor to make it look better than it is.
It's an XR6 motor. That's all.
Like yourself, we know what is in the later XR motors.
You are the ford equivalent of LSx owners using chev badges.
Anchor
Post #76
QUOTE (TwinCam16 @ Mar 20 2012, 09:40 AM) *
henz
Post #77
Lawl. See an Fpv badge anywhere? You are the equivalent of the typical deadshit smile.gif
Your clutching at straws to try troll/ make an argument out of nothing.
The motor, is the same as an Fpv motor. Hence why I stated in brackets. If you already knew this, why all the questions is what I don't get. That's why I think your just failing to grasp the fact that they are the same minus a little bit of paint.
I put it there in brackets as a lot of people don't know that the later motors share the same bottom end, comprende?
Rancher
Post #78
QUOTE (henz @ Mar 20 2012, 12:16 PM) *
SO, Twincam was right. You're the ford equivalent of Holden owners putting Chev badges on their Commodores. Because they are essentially the same motor (Like the Chev lumina!) You decided that you'd put that its a Typhoon motor for no reason whats so ever. For the last bloody time. I'm aware they are the same motor. What I dont get, is why you're calling it a Typhoon motor, When it isn't. What it is, is an XR6T motor with some head work.
And I'm the deadshit. Ok, right.
henz
Post #79
Lawl again at how desperate you are to be right.
Like I said, see an Fpv badge?
The point is, early xr6t = shit motor, late model = good motor.
That make sense for you or would it be easier for you to read if it was written in crayon.
Post #80
QUOTE (henz @ Mar 20 2012, 12:47 PM) *
I said EQUIVALENT, far out... English, is it your second language.
Lets look at the facts...
Your car is not an FPV, does not have an FPV motor, therefore calling the motor an FPV motor is just sackriding FPV's.
A commodore is not a Chev. Therefore putting a Chev badge on it is sackriding Chev.
Get it now durwood?
It's not our fault you couldn't afford an F6.
henz
Post #81
Actually the motor is built by Fpv, so Fpv bottom end. Feel free to point out any differences mechanically for me though.
Would have loved an f6 but at my age it's not the end of the world. Still better than what you own smile.gif
Rancher
Post #82
When you were told its not an FPV motor
Cheers mate.
QUOTE (henz @ Mar 20 2012, 01:01 PM) *
So what is the go? Stronger. The same as. We're not comparing the BA motor to whatever your motor is.
In one part you're saying the FPV have better internals. In another. You're saying they're exactly the same.
What I am saying, for the last time, for the love of god. If you are saying you have an FPV Typhoon motor in your car (Which have different internals, separating it FROM the XR6T motor) Why the fuck does YOUR motor have the standard XR6T red covers? You're not answering the question. At all. You're just trying to prove they are the same (But, different) trying to convince us its an FPV motor.
If you have built it to similar secs. You have built the XF6T motor. Doesn't make it an FPV motor. For the love of god. Answer the fucking question.
Is it that you have built your BA XR6T motor to those specs? Is that it? Then its still not an FPV motor. For crying out loud. All it looks like you're doing, is convince me its an FPV motor, when it left the factory as a BA XR6T motor.
I give in.
Krissy04
Post #83
lol
henz
Post #84
You've quoted it and you still don't understand.
Ok, here you go guys. After 06/06, FPV make all the turbo motors. With no differences ok.
Keeping up?
Coz here's the tricky bit.
Before fitting to the Fpv, they paint the rocker cover.
Woah.
So for the rest of the xr6ts, they leave it red.
henz
Post #85
I don't know how to make it any clearer.
They are exactly the same.
This is bf2 not BA.
Post #86
QUOTE (henz @ Mar 20 2012, 02:23 PM) *
This is bf2 not BA.
I think what they are having a go at you about is calling it an FPV motor. It may be the same as an FPV motor but it did not come out of an FPV. Thats my understanding anyways.
DAZZLER351
Post #87
Hang about , i'm about to bolt a red rocker cover on my F6 but there's no FPV internals it's got ATOMIC parts
and i have a Territory Turbo rocker cover on my N/A and it has ATOMIC parts as well but there is no turbo how is this possible..
tongue.gif at you kid's , wait ..wha??
DAZZLER351
Post #88
And my F6 is a BFII but my XR is a BAII ...
Aaaaaaaaaaaaaaaaaaaaarrrgghh now what the fuck do i do ?????
Rancher
Post #89
QUOTE (henz @ Mar 20 2012, 02:16 PM) *
Keeping up?
Woah.
Nah shit. But, if you read up. YOU have said it was built by FPV, it has a different bottom end. But wait. I thought they were the same?
QUOTE (mark1414 @ Mar 20 2012, 02:35 PM) *
YES.
Why cant your grasp this? What is wrong with you?
DAZZLER351
Post #90
4x4_Commodore
Post #91
F'ing LAWL at this thread. 4 pages and only about 4x cars. Troll much!?
gutless
Post #92
If your engine wasn't released as an FPV motor,then its not an FPV motor.
Stop trying to grasp at owning some sort of engine royalty that isn't true.
henz
Post #93
Cmon then genius's. Show what the mechanical differences are between my 07 and any any fpv.
Here's a hint, theyre the same.
Richie217
Post #94
QUOTE (henz @ Mar 20 2012, 03:51 PM) *
So using your reasoning anyone that has a LS1 powered Holden can claim to have a HSV motor as the are the exact same engine? If they are the same motor we fucking name drop?
OT - Damn these things put out stupid numbers for very little cost. Just a shame I don't really like any of the Falcon bodyshapes since the XD.
DAZZLER351
Post #95
QUOTE (Richie217 @ Mar 20 2012, 04:08 PM) *
But since its a turbo thread...
Page 2 of 5
