RIPGTR
na mate not yet just had too much other shit to do with rebuild this ski boat and all, should whip out the go pros and take some footage lol |
henz
Hey guys. |
force6alex
im tossing up which xr6t ute to get, ba bf or fg. Pros and Cons? This is not a i "wanna" get one, I actually am getting one within a month Maybe 2 if i dont find one i like. you can get a fpv tornado for about the same price as a fg ute i would probably get a tornado over a fg ute but i would probably get a fg over a bf xr6 turbo and i would avoid a ba unless your going to go crazy with mods such as atomic motor and a built gearbox. |
force6alex
yep... 720-730rwhp through T400 i was just reading 1 of my older street fords magazines with your car in it. your car looks awesome as well as being a animal. |
TXR05
thats not a FPV motor... good luck with your clutch too. Hey guys. This is my xr6 turbo ute Tuned by Pitlane Performance. 2007 bf2 (typhoon motor) T56- stock clutch still Plazmaman plenum Plazmaman 1000hp cooler Plazmaman hot and cold side piping Plazmaman billet oil cap Custom 4" intake 9" knN Ported stock turbo with 12psi actuator Xforce 4" dump Rapidsystems 5" cat. 12minths old and starting to rattle. Stock catback. 358rwkw @16psi [email protected] |
force6alex
nice ute henz would be fun. seen your ute on falconxr6turbo.net sounnded pretty sweet with the dose pipe lol |
kizzlemynizzle
My 2010 FG XR6T manual |
force6alex
My 2010 FG XR6T manual pedders lowered springs and leafs K&N pod filter full exhaust doso pipe 19x9.5 all round, wrapped in toyo's got to love ego best colour in my opinion |
henz
thats not a FPV motor... good luck with your clutch too. Yes it is. 2007 build mate. Clutch would be cactus if I drove it hard. But I can't decide weather to do a clutch or a 2-3speed. nice ute henz would be fun. seen your ute on falconxr6turbo.net sounnded pretty sweet with the dose pipe lol Cheers mate. |
henz
Fpv's come with a dark blue tapet cover. And the same coil cover. |
Rancher
Fpv's come with a dark blue tapet cover. And the same coil cover. Every turbo falcon built after 06/06 came with same motor as the FPVs (stronger rods, slightly better valve springs than ba turbos) Fpv started the painted rocker cover, and have carried it through. Feel free to confirm this on any ford forum, or even call ford spare parts. I'm aware of whats done to the FPV motors. Yours has a red tappet cover, and the standard ford coil pack cover. Surely if you had an FPV motor in it, you'd have left the blue tappet cover, and FPV coil pack cover to show off. |
Anchor
I'm aware of whats done to the FPV motors. Yours has a red tappet cover, and the standard ford coil pack cover. Surely if you had an FPV motor in it, you'd have left the blue tappet cover, and FPV coil pack cover to show off. You're missing his point. It's the same motor regardless of tappet cover colour. Whether it came in an XR6T or a Typhoon. |
Anchor
Post #70
Ahh because it's stronger buddy. I wouldn't push 360 out of a BA motor + stock valve springs. Doesn't matter how it looks bonnets shut when I drive. I did. And bashed limiter @ powercruise for 4 days straight with stock oil pump. Tick tock.. And it's still going strong with the new owner. Currently up to 140,000 i think. Had a fresh head since the timing chain got caught up and jumped 4 teeth. New head, straight back on the dyno, same tune. Bores looked fresh, only small marks on pistons. Lucky. These things must have a safety if something like that happens. Car shut down straight away. Also, don't use octane booster. Head and tops of pistons were orange.... |
Rancher
Post #71
Fpv's come with a dark blue tapet cover. And the same coil cover. Every turbo falcon built after 06/06 came with same motor as the FPVs (stronger rods, slightly better valve springs than ba turbos) Fpv started the painted rocker cover, and have carried it through. Feel free to confirm this on any ford forum, or even call ford spare parts. You're missing his point. It's the same motor regardless of tappet cover colour. Whether it came in an XR6T or a Typhoon. Ahh because it's stronger buddy. I wouldn't push 360 out of a BA motor + stock valve springs. Doesn't matter how it looks bonnets shut when I drive. So. What you're saying is. They're both the same motor. But they are different because the FPV motor is stronger. But they are the same with different tappet cover color and coil pack cover. But yours is the FPV motor with the standard red tappet cover and ford coil pack cover. They are the same. But different. Ok. Makes sense. Make up your minds. One of you is saying the FPV motor and XR6T motor is the same thing. The other is saying the FPV motor is stronger. Completely missing my question. If the FPV motor has BLUE tappet cover and FPV coil pack cover (And apparently, stronger rods/valves/valve springs). WHY have you put the RED tappet cover and FORD coil pack cover on the FPV motor? I don't need an explanation about why they are different but the same. Edit: If the point you were trying to make is, they are both a 4LTR turbo I6. Duh. I'm well aware they are. I'm aware they are almost exactly the same, with a few different internal pieces, and more boost. |
henz
Post #72
Fuckkk boost is still full of the same idiots. |
Rancher
Post #73
Fuckkk boost is still full of the same idiots. Ok, after 06/06 EVERY turbo falcon (FPV and xr6t) came with the exact same motor. Same rods, same valve springs, every part. The xr6ts though, still have the red tapet cover. Fpv have continued the blue theme they started originally. As for a BA making 360, can 450 if you want. But I personally wouldn't & didn't with my own BA. Yeah, you're one of them. Read what I'm saying you moron. You have said you have an FPV motor. The picture you posted is clearly an XR6T motor. FPV have blue. Ford has red. Yours has red. WTF? Don't spin this on me. ANSWER THE DAMN QUESTION. FFS. I understand they are the same motor. Stop trying to tell me that. Answer my question. FPV has blue. YOU MOTOR, that is pictured above. Is red. Why. |
julio_vasquez
Post #74
Fuckkk boost is still full of the same idiots. Ok, after 06/06 EVERY turbo falcon (FPV and xr6t) came with the exact same motor. Same rods, same valve springs, every part. The xr6ts though, still have the red tapet cover. Fpv have continued the blue theme they started originally. As for a BA making 360, can 450 if you want. But I personally wouldn't & didn't with my own BA. So you have an XR6t motor. Not FPV because you have the red tappet cover. Regardless if they are the same thing besides what they look like. Yours looks like an XR6t motor not FPV. |
Post #75
Ahh the old retaliation of "fuck this site is full of xxxxx" |
henz
Post #77
Lawl. See an Fpv badge anywhere? You are the equivalent of the typical deadshit |
Rancher
Post #78
Lawl. See an Fpv badge anywhere? You are the equivalent of the typical deadshit Your clutching at straws to try troll/ make an argument out of nothing. The motor, is the same as an Fpv motor. Hence why I stated in brackets. If you already knew this, why all the questions is what I don't get. That's why I think your just failing to grasp the fact that they are the same minus a little bit of paint. I put it there in brackets as a lot of people don't know that the later motors share the same bottom end, comprende? SO, Twincam was right. You're the ford equivalent of Holden owners putting Chev badges on their Commodores. Because they are essentially the same motor (Like the Chev lumina!) You decided that you'd put that its a Typhoon motor for no reason whats so ever. For the last bloody time. I'm aware they are the same motor. What I dont get, is why you're calling it a Typhoon motor, When it isn't. What it is, is an XR6T motor with some head work. And I'm the deadshit. Ok, right. |
Post #80
Lawl again at how desperate you are to be right. Like I said, see an Fpv badge? The point is, early xr6t = shit motor, late model = good motor. That make sense for you or would it be easier for you to read if it was written in crayon. I said EQUIVALENT, far out... English, is it your second language. Lets look at the facts... Your car is not an FPV, does not have an FPV motor, therefore calling the motor an FPV motor is just sackriding FPV's. A commodore is not a Chev. Therefore putting a Chev badge on it is sackriding Chev. Get it now durwood? It's not our fault you couldn't afford an F6. |
Rancher
Post #82
When you were told its not an FPV motor Yes it is. 2007 build mate. Clutch would be cactus if I drove it hard. But I can't decide weather to do a clutch or a 2-3speed. Cheers mate. Fpv's come with a dark blue tapet cover. And the same coil cover. Every turbo falcon built after 06/06 came with same motor as the FPVs (stronger rods, slightly better valve springs than ba turbos) Fpv started the painted rocker cover, and have carried it through. Feel free to confirm this on any ford forum, or even call ford spare parts. Fuckkk boost is still full of the same idiots. Ok, after 06/06 EVERY turbo falcon (FPV and xr6t) came with the exact same motor. Same rods, same valve springs, every part. The xr6ts though, still have the red tapet cover. Fpv have continued the blue theme they started originally. As for a BA making 360, can 450 if you want. But I personally wouldn't & didn't with my own BA. Lawl. See an Fpv badge anywhere? You are the equivalent of the typical deadshit Your clutching at straws to try troll/ make an argument out of nothing. The motor, is the same as an Fpv motor. Hence why I stated in brackets. If you already knew this, why all the questions is what I don't get. That's why I think your just failing to grasp the fact that they are the same minus a little bit of paint. I put it there in brackets as a lot of people don't know that the later motors share the same bottom end, comprende? Actually the motor is built by Fpv, so Fpv bottom end. Feel free to point out any differences mechanically for me though. Would have loved an f6 but at my age it's not the end of the world. Still better than what you own So what is the go? Stronger. The same as. We're not comparing the BA motor to whatever your motor is. In one part you're saying the FPV have better internals. In another. You're saying they're exactly the same. What I am saying, for the last time, for the love of god. If you are saying you have an FPV Typhoon motor in your car (Which have different internals, separating it FROM the XR6T motor) Why the fuck does YOUR motor have the standard XR6T red covers? You're not answering the question. At all. You're just trying to prove they are the same (But, different) trying to convince us its an FPV motor. If you have built it to similar secs. You have built the XF6T motor. Doesn't make it an FPV motor. For the love of god. Answer the fucking question. Is it that you have built your BA XR6T motor to those specs? Is that it? Then its still not an FPV motor. For crying out loud. All it looks like you're doing, is convince me its an FPV motor, when it left the factory as a BA XR6T motor. I give in. |
henz
Post #84
You've quoted it and you still don't understand. |
