gutless
Post #131
Funny Thing is... Both engines are still made at Fords engine plant, on the same production line, using the same parts. So, towards the end of the production line... -One goes and has the Blue tappet cover installed, and is coupled with a FPV tune, then installed in a FPV -The other has the red cover, and a XR6 tune, then is installed in a XR6 Hence, Typhoons having a FPV tuned variant of a Ford engine (as ford simplified things by having the one set of rotating assembly)... Therefore, saying your XR6 is sack riding....unless you own a BA-BF Mk1 and have installed a FPV spec engine... If this statement about where they come from is true, its as much the same as people that claim an LS Engine is a Chevrolet motor when in fact its roots are neither Holden Nor Chevrolet as they are GM motors. The only thing making them a such-n-such engine pertains to the Chassis they were installed in. So in closing, Henz can just get on it and give up. |
fpvxr6t
Post #132
If this statement about where they come from is true, its as much the same as people that claim an LS Engine is a Chevrolet motor when in fact its roots are neither Holden Nor Chevrolet as they are GM motors. The only thing making them a such-n-such engine pertains to the Chassis they were installed in. So in closing, Henz can just get on it and give up. The difference here being that in its roots, Ford make Ford engines, Holden don't make Holden engines. And the chassis they come in does not define the engine. The tune the engine gets before being installed as the Ford stock tuned engine, or the FPV tuned engine defines what engine it is. |
gutless
Post #135
The difference here being that in its roots, Ford make Ford engines, Holden don't make Holden engines. And the chassis they come in does not define the engine. The tune the engine gets before being installed as the Ford stock tuned engine, or the FPV tuned engine defines what engine it is. Oh big difference. GM>Holden/Chevrolet Ford>XR6T/Typhoon. Companies/Models Potato/Potahto. Your statement is quite silly. The only reason the FPV engine gets an FPV tune is because its in an FPV. Tune/Covers disregarded, one of these motors installed into an XR6T from Factory is an XR6T motor and the same with FPV #Circles. |
fpvxr6t
Post #136
Oh big difference. GM>Holden/Chevrolet Ford>XR6T/Typhoon. Companies/Models Potato/Potahto. Your statement is quite silly. The only reason the FPV engine gets an FPV tune is because its in an FPV. Tune/Covers disregarded, one of these motors installed into an XR6T from Factory is an XR6T motor and the same with FPV #Circles. They're not the same.. Companies and models are the same thing? And you have just said exactly what I've been saying in your second comment.... I haven't argued the reason why it gets an FPV tune so not sure why you're bringing it up As said a few posts ago again... As said 2 posts ago: "The summary is, yes the 2 engines are built the same before dropped into any car. The XR6T's come with an XR6T configured/tuned engine. The FPV's come with an FPV configured/tuned engine." The engines are the same in terms of build parts, one being tuned by FPV for an FPV F6, the other tuned by Ford the way it is for the XR6T. Therefore, final product - one is an F6 engine, one is an XR6T engine. I have never contested this. Circles indeed... |
TurboXR
Post #137
oh dear... Just FYI, holden make Alloytecs Offtopic...Alloytec was a joint venture by Cadillac and Holden. Ford 4.0 I6 is pretty much now the only Australian engineered motor (as in not just assembeled in Aus like the Holden Cruze) left but started out as an American motor although only as a 144ci, 170ci and 200ci, Ford Aus pretty much changed all the internals, etc in 1968 and again in 1970 with the good old 250ci. |
sideways82
Post #138
so where does mine fit in in this shitefite |
TurboXR
Post #139
so where does mine fit in in this shitefite BF mk2 xr6t with the motor out of a BA fpv f6 ((blue rocker cover(yes i know, i know)) with atomic 698 internals, valve springs and harmonic balancer? hahaha dont keep that argument going. Well you just found the answer yourself with the Atomic internals.....I'd call it a built Ford I6 Turbo motor |
sideways82
Post #141
back on topic - lightning strike BF with 380rwkw and a built motor |
INVU
Post #148
xr6 turbo stage 2 process west intercooler kit,aftermarket larger fuel pump, rear dimpled&slotted rotors with pads all suit ba xr6 turbo. All items are brand new and unused still in there packaging. $1200 ono for the lot can text pics ph:0432273815 this shit aint no classifields section, @#$!. |
Ticc
Post #156
2003 ba xr6t ute |
DAZZLER351
Post #160
Is that your car dazzler?, what mods? Type it all out later mate Here is a vid http://youtu.be/Cort5AUJTXU |
