Page 8 of 66
Anchor
Post #246
Pulled out the rear seat and the rest of the carpet, found 10c american. And no more rust. Yay
Protius
Post #247
QUOTE (Akshunhiro @ Apr 16 2011, 01:23 PM) *
Changed the battery after finding it had a lead acid in the boot. Put my Optima D34 in. Was also surprised there wasn't a fuse at the battery...
Put my Pioneer headunit in too since it shits all over the Alpine that was in it. Sounds good man!
Might adjust the rear coilovers later if I could be fucked.
jeepn
Post #248
reversed it out of the garage,
washed it, then put it back in to sit again.
E U R E K A M A D 9 4
Post #249
Got bored on friday, put the back wheels on the front for some fitment lulz.
Goku
Post #250
Beat a vx ss
Felt so nice
-Jordan-
Post #251
QUOTE (Anchor @ Apr 16 2011, 01:59 PM) *
OT: ripped out the rear seat, seatbelts, speakers and parcel shelf all cause I didn't realise you can't put the little corner peice of the PS in afterwards.
Not happy...
Post #252
Sold it !!!
Now im currently car shopping on carpoint.....hmmmm new series 2 SV6......wink.gif
Geoff
Post #253
Tried to ghetto rig the wiring on the latest bushwagon mustering rig, a D21 navara.
This is much easier on older cars.
Rileys
Post #254
- cut rubber matting to size
- removed the racks that Caddy had put in the car
- installed rubber matting
- modified the location of the shelves to give me more room down the middle of the canopy
shelves are now "quick release" so it takes about 30 seconds to remove them when i need to use the ute as a ute
chaserface
Post #255
tried to do a wheel alignment on my drive way using my eye...... failed. going to have to spend the forty dollars to get it done. sad.gif
Joyrid3r
Post #256
QUOTE (chaserface @ Apr 16 2011, 07:05 PM) *
Post #257
Not my car... but one I WAS looking at purchasing, just found out all series 2 sv6's are 210kw. P plate laws are again flawed by this shit.
DAL32
Post #258
Got headunit working (the first time not working was a HUGE derp on my part... it didn't work because I didn't turn it on... fucking LOL).
Wired up amp and sub. Made up a patented interference fit boot install using a bag-of-rags preventing the amp from falling into the space below the sub.
Proceeded with hectic doofs. Goes bloody hard for just a 10" sub.
Discovered front right speakers not working. Yay, more fun working in tight spots.
W1NT3R
Post #259
Got the shits with it. Wiring is ghey
GTRwilson
Post #260
Took it for the first official cruise since getting it back on the road. Had some fun with it later in the arvo, and fucked one tyre. sad.gif
Sharpy
Post #261
QUOTE (GTRwilson @ Apr 17 2011, 08:39 PM) *
Also took mine on its first drive through the mountains in a while. apparently im blowing foot long flames. awesome. Tune on the 30th
Slide_thats5
Post #262
got a tune took it for a drive and snapped a axle
j.d.m
Post #263
primed the lip spoiler and blocked it down. tmrw will paint.clear it all. then install it when dry and adjust minor things to make it sit right
GTRwilson
Post #264
QUOTE (Sharpy @ Apr 17 2011, 08:42 PM) *
Dont know what you're talking about. oopsie.gif It was weird, it didnt blow, just peeled off a big strip of rubber down the middle of the tyre. dunno.gif Useless last owner getting some unknown 'new to the market' tyres.
Anchor
Post #265
Turned this,
into this,
using this.
Inspiration from Warney.. Haha
Zimma
Post #266
Wasted a day getting door trims off, trying to work out how to get new speakers in, end result i have 1 wired up and working 6.5" split thats loose on my front seat and no door trims..
jish
Post #267
Fit locker.
Did test skid.
Profit.
Manic 180
Post #268
Bought a 1983 Datsun bluebird with some mates and filled it with toluene.
next week will weld the diff, cut and weld the front doors to 1/3 height and beef up the cooling system.
Rileys
Post #269
QUOTE (Zimma @ Apr 17 2011, 09:07 PM) *
you have a toyota right? if door trims take you any longer then 5 minutes i think its time to put the screw driver and step away from the vehicle
pro tip: if you cant modify the existing speaker mount, make your own out of mdf to suit the speaker and the door, keeping in mind the window/window mechanism and speaker depth
ot: detailed the work car......made a huge difference even on paint thats only a few weeks old....main idea with the car is to protect the paint and interior as much as possible to keep it nice for as long as possible - also to make it easy keep clean in the future
Anchor
Post #270
QUOTE (Manic 180 @ Apr 17 2011, 09:15 PM) *
Bought a 1983 Datsun bluebird and filled it with toluene.
They are awesome daily's. I've got the wagon version. The other day i hit 135km/hr!!
warney
Post #271
QUOTE (Anchor @ Apr 17 2011, 09:03 PM) *
Turned this,
into this,
using this.
Manic 180
Post #272
QUOTE (Anchor @ Apr 17 2011, 09:16 PM) *
It is a wagon. Only the best for this project! 135 would be scary haha
Anchor
Post #273
QUOTE (Manic 180 @ Apr 17 2011, 09:48 PM) *
Haha shityeah!!
Mine is auto, so damn slow lol.
Capriv8
Post #274
What a productive Sunday!
Ever since this happened (last Feb), we've had a perfectly good GTi engine, box and bits sitting there, rusting away in the orchard.
We got a new donor car last weekend: a good condition Mk3 GTi minus running gear = $100. I spent last Saturday stripping it out.
Work started with the door being forcibly removed from the crashed GTi with a crowbar, big ass hammer and a chisel.
Found it had lowered springs and adjustable struts! SCORE!
Many hours of toiling later... That night i fitted the Mk2 loom to the Mk3, and fucked around endlessly trying to get the Mk2 dash to fit, with the steering column and ignition also being different for no good reason. Found the block had a broken engine mount hole which will need a bracket made up.
Final plans are a roll cage, bucket seat, ecu chip, pod filter, exhaust and 60mm throttle body and FPR. Easy peasy!
Innuendo
Post #275
QUOTE (Be-Hating @ Apr 15 2011, 09:51 PM) *
But, It's a magna?
Exactly! Going to have a hard enough time selling it as it is!
jebby88
Post #276
Put a new aerial on it, tightened the head bolts,adjusted the rear drums. Brought a new club lock
Geoff
Post #277
New oil, oil filter, air filter, fuel filter an AC belt in thr rustbucket 75 series from my last post in here.
Like a bought one now!
HarleyJace
Post #278
Fitted my JAF badge, put in the radiator, Hooked up some hoses, bolted in headlights and what not.
Geoff
Post #279
Took apart the rear/right wheel hub on Top Deck the 40 series ute. Hunting thru the bush tomorrow for a new one.
Got given directions to a 60 series thats lying out in the never never (got left therr to rot late last year after the motor went catus'd). Its real "Turn left at the black stump" type stuff. See what we can find haha. I love living here sometimes.
S4rdonic
Post #280
Wheel alignment yesterday, service and autobox service today, plus found a st140 corona to buy as a project sleeper. Will fix interior in the daily thats falling off tomorrow cbf to do it today.
Page 8 of 66
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
