Page 60 of 66
vtrikk
Post #2066
QUOTE (TheMurrizzle @ Jan 9 2013, 12:56 AM) *
Filled up the washer bottle.
I still for the life of me can't understand how that is a defect.
Ot: over the last week, removed tint, fitted new wheels, installed manual boost controller, new spark plugs and coil packs one happy camper smile.gif
rus_s13
Post #2067
Attempted to drive to work this morning, engine said no.
Lots tonight, f*ck sr20's
Luke
Post #2068
Changed the strut bar to chassis bushes. Difference is incredible! The brakes feel that much more responsive, and the stability of the car under brakes has increased dramatically! Only took me about an hour as well, very easy to do. Can not speak highly enough of the Nolathane 48166 kit!
Old, shitty bushes.
Pretty new red Nolathane ones!
For sale: 2 genuine GM strut bar to chassis bushes. Second hand, only fitted once! For inquiries and inspection, please see the wheelie bin on my nature strip.
DAL32
Post #2069
Ah, response. It's the thing you get when you give up ride quality.
I'd poly bush my but can't be bothered unless the bushes are fcuked.
VGJONO
Post #2070
Replaced the front wheel bearings after the front left started making a horrible whining when i tried to drive to the shops the other day. sure enough the old bearings were surrounded by metal shavings, since the grease was red i have a suspicion that the last time the bearings were done, somebody may have picked up rubber grease instead of Bearing grease unsure.gif
Twat In The Hat
Post #2071
QUOTE (vtrikk @ Jan 9 2013, 02:15 AM) *
Been explained before a few times..
Let's say a bird takes a giant shit/a mud puddle gets sprayed/dust from the dirt road you're on/1,000 angry bees smash into your windscreen while you're driving.. Your automatic reaction is to pull back on the wipers to squirt some onto the screen.. Right? Well empty bottle, you get nothing, but the wipers start working. Now you have bird shit/mud/dust/bugs smeared all over your windscreen rather than being cleaned off because you have no water.
j.d.m
Post #2072
Installed coilovers last night, Set height, will get wheel alignment on Tuesday.
Luke
Post #2073
All of the above today; plugs, manifold insulators, and water inlet seals.
After two emergency trips to Repco (First because one of the bolts for the inlet housing snapped, and second because one of the coils came apart) it's all back together now. Just waiting on the silicon to dry.
Post #2074
laugh.gif Cute.
RB25_lovin
Post #2075
sold the skyline. i will miss her, until i get something better and then i probably wont
Protius
Post #2076
What do those manifold insulators do? Are they the same idea as what they make for WRX. Slightly increasing the intake runner length making for ever so slight increase in torque?
Post #2077
Pretty much, also the spacing from the block is meant to drop intake temps.
It's more a "pissing into the wind" mod like a pod filter to be honest.
stockmy00
Post #2078
placebo effect
j.d.m
Post #2079
bought a mspec frontbar
after 4 hrs of non stop sanding, and half a box of 120G sand paper, got it to the FIRST coat of primer ever put on it in it's life. someone did a diy respray 3 times on it and had paint flakes
Primed and sanded down, then mist coat
Result after 4 coats base coat and 4 coats clear
HarlzC
Post #2080
Unbolted the mufflers on the SS, sounds a bit better than stock now haha.
Draven
Post #2081
QUOTE (HarlzC @ Feb 10 2013, 09:15 PM) *
unsentletter
Post #2082
fitted new Monroe Gas shocks and King Springs to the Dato
54BRE
Post #2083
scoobydoo23
Post #2084
Looked at it
got depressed
Kick it
Went back inside
scottypipen101
Post #2085
dropped a skid cause im tuff as
astorey
Post #2086
QUOTE (54BRE @ Feb 11 2013, 07:50 PM) *
WHY DO YOU HAVE TO MAKE VAGUEBOOK POSTS.
What did you buy?
truffles
Post #2087
Put on of them in the shed, covered it up and hoped to work on it in more favourable times.
The Doctor
Post #2088
pissed off the yellow parker and foggie bulbs with LED's
Geoff
Post #2089
Sold it.
bandit_corolla
Post #2090
finally finishd my front lip and sideskirt. there might be a diy thread on how to make one, didnt take that much pic but ill see what i can do if you really wanna see it.
VGJONO
Post #2091
Pulled my new motor out of the parts car
(as far as i know it has some head work, 40thou over pistons and is decompressed and ready for boost biggrin.gif )
Pulled the old motor out of my car
(new on left/old on the right)
Cheers
The Doctor
Post #2092
Front lip installed. leaving the colour as is.
Eugene Dickins
Post #2093
Lip looks awesome
renewed the rego for the jeep for 6 months. Will prob sell it within that 6 months.
Auditude
Post #2094
My headlights magically became darker :oopsie:
aaron.
Post #2095
Went to install my prototype 3-step rev limiter;
Engine running like shit and white smoke from exhaust out of nowhere, didn't finish installing rev limiter.
Hopefully it's not raining tomorrow so I can diagnose the engine problems and install the limiter. BHG would suck ass.
j.d.m
Post #2096
And other dash trim pieces, no more rattlecan black
The Doctor
Post #2097
3rd brake light redout overlay
ugly chrome window trim
be gone!
DAL32
Post #2098
Found that my bodge fix of my drivers door cable is failing, devised new way of opening door from the inside. A combination of pushing the door and pulling the handle at the same time in one swift move, give the door somewhat of a kick while pulling the handle sharply.
_Ben
Post #2099
Put some clear side indicators on the AU, for max ADM swag
j.d.m
Post #2100
Install my Headlights and relocate some wires.
Page 60 of 66
47 User(s) are reading this topic (47 Guests and 0 Anonymous Users)
