Page 59 of 66
Geoff
Post #2031
It was sunny and delishus back home. Im never driving through country Victoria again you can bet on that. Have any of the cxnts that build roads here ever heard of grading and rolling the surface flat before they throw down the bitumen? f**king rollercoaster ride that Western Hwy (when youre not doing 25kmh in roadworks).
Also FWIW:
patrick_h_oz
Post #2032
Compression tested the poor beast after losing all the coolant the other afternoon- 0, 140, <30, <30.. dammit! head_wall.gif
I guess I'll pull the head and see how bad it is... there's bound to be piston damage with results that bad. The needle didn't move when I tested No1.. tears.gif
aloshan
Post #2033
installed boost controller & intercooler
vtrikk
Post #2034
QUOTE (aloshan @ Dec 22 2012, 11:41 PM) *
Snip*
I also installed a boost controller the other day, running 10psi would hit 10 about 4 grand revs them spike to 18psi and boost cut at 5.500 revs. Fixed the problem but now won't boost past 7. Thinking its because of the standard actuator, did you have this problem? Also mine is only series 1.
V3N0M
Post #2035
Had dear Rancher come over and play doctor
Finally got the ECU to show 55 (All clear)
Turns out the timing belt has skipped a tooth ><
So next step is getting the timing belt done (f**king Series 2)
BAM!
Post #2036
Stripped my interior and started taking off the chrome mouldings on the outside of her. The painter mate of my dad's who came round "had a look and quote" to give her a clean up and spray reckons "at mates rates" it'll cost me 4 to 5k. 2k worth of materials, the rest is labour. And that's after I get it blasted. Says that every panel has rust in it and that it has to be cut out and/or glassed. I stripped everything right back to a bare shell this morning and I can sincerely say that there is sweet f**k all rust in her anywhere. The worst part being the tailgate which will be replaced anyway. This guy just seemed like a gigantic douche. I also priced the paint I want it done in, 1k is all it'll cost for the paint, thinners and hardeners....
RB25_lovin
Post #2037
installed some 3m thick bash plates because the old ones were f**ked.
DAL32
Post #2038
Washed it, took photos, advertised on here, and receiving SMS scams already FTW!
moparguy
Post #2039
Should've read:
Hey mate, very interested in your car for sale. Please inform me of your lowest cost. Peply to mee at [email protected]
edit: Yes it's a lot for a FWD but I don't plan on selling this car dunno.gif
DAL32
Post #2040
You know I've got 3 cars right?
moparguy
Post #2041
But in your write up/biography > tongue.gif
tih2ho
Post #2042
thought it was time to replace a wheel bearing, jacked up car, had a beer, removed wheel, brake caliper and disc, had a beer. don't have a 32mm socket - hit that with a big ass screwdriver and hammer. didn't work. had a beer, sprayed wd40 on nut n thread, got a lift to bunnings (only shop open) no long 32mm sockets. back to car. another beer. hit that with a hammer again, nothing, thinkin, had a beer, thinkin, had a beer, thinkin, had a beer, wtf am i doin outside? came inside. look out window and see some f&#ker has jacked up my car. go investigate, looks like part way through a wheel bearing replacement - oh yeah, that was me smile.gif time for another beer, will get a socket tomorrow maybe....
aloshan
Post #2043
QUOTE (vtrikk @ Dec 23 2012, 10:49 AM) *
which controller did you install?
i had this problem slightly , setting it to 12 , would result it in jumping to 13-14 and boost cut kicking in. I basically just set it to 11 to compensate for it possibly hitting 13 and even then , fuel cut shouldn't kick in. Only does this in first and second gear under high revs though.
i guess its dependent upon the type of boost controller you have
TXR05
Post #2044
Washed twice, polished, then waxed.
VGJONO
Post #2045
Noticed the original seat frame was bent, remembered the aftermarket seat i had, after a few hours some "ghettoed"seat rails were made and said seats where installed, immediate regret was felt mamoru.gif and im now waiting on a reply for some new seats that will fit, either that or a nice officer to laugh when i get pulled over bowrofl.gif its defenantly one of the dumbest things ive done
Bob
Post #2046
Double checked the speedo. 100 in first and 200 in 250metres...
vtrikk
Post #2047
QUOTE (aloshan @ Dec 23 2012, 04:46 PM) *
Yeah I noticed that it would only do it in first and second even when I had the problem sorted, was still spluttering around 6 grand. I figured it couldn't be normal and wound it down to 9 and problem seems to have gone altogether. Am running a turbo smart manual boost controller. Have a 2 stage just can't be bothered with the wiring haha.
the shadow
Post #2048
Might vacuum it tomorrow
JayJay
Post #2049
Did some minor Exhaust fabrication. Made a custom exhaust bracket on to my gear box cross member and used an FJ45 cruiser mount to get my Y-pipe as close as possible to the body in preparation for the new suspension arriving this week. Then it will be the decision of HID conversion or top swap supercharged conversion.
AGI78-VP
Post #2050
started polishing up the 2nd hand blower i picked up last week
Nothingman
Post #2051
Cleaned and polished both.
02GZM
Post #2052
Installed my new grille.
VGJONO
Post #2053
washed it for the first time in a while took me an hour to remove all of the Grubby tree sap that fell on it overnight (first and last time i ever park it under a tree angry.gif )
Post #2054
F@%$!!!!!
_Ben
Post #2055
QUOTE (TwinCam16 @ Dec 28 2012, 11:17 AM) *
F@%$!!!!!
EssR20
Post #2056
F@%$!!!!!
Unlucky mate, i know that sound all to well.
BAM!
Post #2057
F@%$!!!!!
<object type="application/x-shockwave-flash" height="468" width="625" data="https://www.youtube.com/v/ZH4ZXO_ys4M"><param name="movie" value="https://www.youtube.com/v/ZH4ZXO_ys4M"><param name="allowScriptAccess" value="sameDomain"><param name="quality" value="best"><param name="bgcolor" value="#FFFFFF"><param name="scale" value="noScale"><param name="salign" value="TL"><param name="FlashVars" value="playerMode=embedded" /><param name="wmode" value="transparent"/></object>
Mmm sounds healthy!
Nobody Actually
Post #2058
ouch
75 KINGSWOOD
Post #2059
Drilled some brackets and fitted my stereo into my glove box, repainted power steering bracket and pump, made and painted some panels to cover the stereo hole as well as my column auto indicator.
rus_s13
Post #2060
Cleaned out the dog sh!t someone managed to get in both rear foot-wells whilst I was playing taxi
Explains the odd smell last night
J2
Post #2061
Deleted bov, added bunnings chair stoppers instead.
SHHHHHHHHTUUU TU TU TUTUTU
ShanO`
Post #2062
Got a mechanic to change a couple of coolant hoses under the plenum, I also topped up the gearbox oil.
Now to source myself a new diff and I will be able to drive it properly again
RB25_lovin
Post #2063
F@%$!!!!!
DAL32
Post #2064
Yesterday. Found that the ICV had self destructed, hence no idle. Yee-ha $200 part
Hooray for back up racecar. That is what I'm calling it until I put a headunit back in it tomorrow night.
TheMurrizzle
Post #2065
Filled up the washer bottle.
Page 59 of 66
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
