Page 49 of 66
DAL32
Post #1681
TE37s
stockmy00
Post #1682
QUOTE (autech_s15 @ Jun 17 2012, 09:29 PM) *
Are they genuine te37s or those Vork Ravs?
They look like the real deal
autech_s15
Post #1683
Nice work. They look good on your car
DAL32
Post #1684
Yeah I love the look. The 30 offset wasn't enough though ph34r.gif (as in would not clear brakes)
autech_s15
Post #1685
european offset is so backwards.
DAL32
Post #1686
Stock wheel on the Alfa is +30 but basically the wheel looks like a +50 offset in design and has a "spacer" built into the mounting face of the wheel, about 12mm worth compared to any normal wheel.
Post #1687
And people wonder why hardly anybody wants to buy from/deal with local automotive businesses anymore. Have just been into a general mechanics, a steering/brake shop and a bearing 'specialist' to have the supporting bearing swapped between the factory and quick-rack input shaft on my steering rack only to be told it was impossible/unable to be done without destroying the old shaft and bearing/etc. I know this is complete bullshit. Stopped in at Johnson Transmissions @ Brendale for a final opinion before giving up - the two old blokes there had it swapped in a minute and didn't charge me for it. Guess who's getting my business in the future.
Yay, rack is finally done.
Quaife QSR/new boots/tie rods/rod ends/etc
Catapult
Post #1688
Re-tuned the auto, fitted lowered suspension springs and struts in the rear, new setup in the front also, full service, fitted a sub, happy boy!
Geoff
Post #1689
Bought myself an 08 GLX triton 2 weeks ago and the first thing i did was fit up a UHF radio - a Uniden UHN7760NB remote head jobbie. Mounted the unit up under the dash hidden away.
Then came the 265/75R16 Mickey Thompson Baja ATZ 4 rib tyres on 16x8 sunnies (cruiser offset). Those motherfunkers were hanging out like wizard sleeves in a Valley alleyway at 2am.
Drove from the tyre shop in Osborne Park like that back to my house in Greenmount LOL. Via bunnings for some flares. Some might call it garden edging and well, they'd be 100% right but god damn the car looks good now:
Going for its first wheel tomorrow, up to Lancelin for the day and then an easy run through the Powerlines on Sunday.
Rileys
Post #1690
That looks the tits Geoff
B Unit
Post #1691
I was asked to switch projects at work and they threw in a company car to sweeten the deal. Downside is, it's a Proton Jumpbuck ute with over 160k on the clock. So I went to fill it up yesterday for the first time and just grabbed the cheapest unleaded (91Ron) pump when I noticed it has a sticker inside the fuel cap flap saying to use 95Ron minimum laugh.gif It was pinging before, let's see how it goes now.
VersionR
Post #1692
QUOTE (the_random_hero @ Jun 26 2012, 04:06 PM) *
I agree, got ENZED to make my turbo oil feed, charged me $140 which i thought was a little excessive but oh well. Recently wanted it cut and another T piece fitted for an oil pressure gauge, simple job, I ring Pirtek first and ask them if they can do it and how much. "Dunno, you'll have to bring it in so we can see if we can do it or not". "Pirtek has been around for 30 years and you're telling me you dont know if you can cut a teflon braided oil line and fit a simple T piece in it?" Silence. funk off useless merchant bitch
ShanO`
Post #1693
Gave the daily Falcon a service and fitted some coilovers.
Need to Drop the front another 10-15mm and raise the rear a little so it sits even. Also need to fit a set of shorter bumpstops which should be here by the end of the week. biggrin.gif
Geoff
Post #1694
Drove it
B Unit
Post #1695
105k service on my Transit van, so it's running really nice. Time to clean it and sell it.
S2krazie
Post #1696
Can I have my wing back since my NSX-R wing never arrived. LOL
B Unit
Post #1697
QUOTE (S2krazie @ Jul 2 2012, 07:57 PM) *
.Woody.
Post #1698
Put it on a hoist at work, dropped lower strut braces, subframe and exhaust center section out,. Removed the swaybar, then put everything else back on. So happy I have no more squeaks and squeals!! Now to either leave it off or sort out a custom bar mounted externally.
Also found that my transmission fluid was waaaaay overfilled by someone... let all the excess drain out haha.
VersionR
Post #1699
Wiring in an Apexi SAFC II now, took me funking ages just to find the ever elusive ecu. When I'm done I will put in my 460cc injectors
Rileys
Post #1700
Some new speakers for dads cressy in the rear. The original ones had almost perished
Post #1701
Flashtune for the daily. Ohai 320NM@1900rpm
wolfman101
Post #1702
Center stack out, new one in.
Still have to put in the new door speakers to go with the amp.
VersionR
Post #1703
Ditched engine fan in favour of twin thermos
wolfman101
Post #1704
So you can keep two cups of coffee warm simultaneously?
VersionR
Post #1705
Thats correct, and its super effective too!
Post #1706
Not my car, but was moulded off my parts. Slight bit of tweaking and they'll be ready to rumble.
VersionR
Post #1707
What is it?
Fitted 6 speakers, amp, sub and head unit, finally have something other than triple M to listen to. Gave it a wash and vac too
Luke
Post #1708
Got some VY SS S2 wagon tail lights the other day.
Driver's side done:
Standard:
VY SS light:
Both done!
ps: Yes, I know my car is filthy...it's well overdue for a good wash and some TLC...
Post #1709
QUOTE (VersionR @ Jul 15 2012, 07:05 PM) *
What is it?
Carbon fibre rear visor.
Mr.B
Post #1710
Washed and cleaned then scratched head as to where I can put the oil catch can.
autech_s15
Post #1711
Painted my cam cover for my new engine
VersionR
Post #1712
How is the engine build coming along autech? Who's doing it?
autech_s15
Post #1713
QUOTE (VersionR @ Jul 16 2012, 09:11 PM) *
I bought a stock SR20DET with about 90 thou on it from Dave @ Japanese Parts and Performance for the time being. I'm in the process of putting that engine in and getting the car running/regoed etc.
Once that is out of the way, I'm stripping the blown engine down myself and rebuilding it.
Forged bottom end (Rods/pistons)
Block bored/honed/decked
Head decked
New valves/springs/retainers/cams/head studs etc
3071r
Will be a pretty decent build Aiming for 400hp
Sharpy
Post #1714
Serviced it, changed the scummy plugs, was overfuelling like a bitch, missing, backfiring
Was driving good again after! YAY! still needs a touch up tune. It's still a tad rich (this is after changing plugs, idling for about a minute
Washed the POS
VersionR
Post #1715
QUOTE (autech_s15 @ Jul 16 2012, 10:22 PM) *
Head decked
3071r
What about tuning, you know anyone good, nissan guru's etc up your way? I'm moving from Sydney to GC soon and wanna get a decent tuner when I rebuild my KA, not many people seem to know the go with them down here
Page 49 of 66
120 User(s) are reading this topic (120 Guests and 0 Anonymous Users)
