Page 48 of 66
AGI78-VP
Post #1646
New wheels, gone for the "fitment" look, 19x9.5 with 235/35/19's all round. still gotta pump and roll the guards then wind down the coilovers
Chris
Post #1647
That looks funking awesome.
Nothingman
Post #1648
QUOTE (AGI78-VP @ May 27 2012, 08:20 PM) *
<snip>
That looks awesome, imo the rims suit nicely but I've always been a fan of monaros.
OT: Oil change, oil filter change and air filter change.
Found the source of the leak in my coolant reservoir turns out it is a join between the clear plastic and black plastic beside the radiator. I coated it with pvc cement fingers crossed it fixed it (no leaks yet) if not I'm going to try silicon (worth a shot) and then either have to source something from a wreckers and replace it myself or give it to a proper mechanic sad.gif
edit: I misspelt oil....
_Ben
Post #1649
Those wheels look sick as sh!t
autech_s15
Post #1650
Made 190kw at the rear wheels at 16psi at 101 today.
pick it up friday. So happy
Aarie
Post #1651
QUOTE (autech_s15 @ May 30 2012, 06:25 PM) *
Made 190kw at the rear wheels at 101 today.
Is that on the proper tune? As in not a run-in?
autech_s15
Post #1652
QUOTE (Aarie @ May 30 2012, 05:26 PM) *
Yeah proper tune.
With the following mods:
Power Fc
s15 440cc injectors
s15 T28 Brush Bearing
NA cams
walbro 255
Front mount
3" from dump full stainless exhaust
Aarie
Post #1653
QUOTE (autech_s15 @ May 30 2012, 06:31 PM) *
Yeah proper tune.
Power Fc
s15 440cc injectors
NA cams
walbro 255
Front mount
Thats alot of poke from a mild build, good stuff. Will you be increaseing the power any more at a later date? That's still going to be quite fast though (and quiet, love the dynamatt job)
autech_s15
Post #1654
QUOTE (Aarie @ May 30 2012, 05:44 PM) *
for now I just want to get it on the road and get it running. once I'm comfortable with that power ill look to going for more
Sharpy
Post #1655
QUOTE (autech_s15 @ May 30 2012, 06:00 PM) *
autech_s15
Post #1656
Sharpy
Post #1657
QUOTE (autech_s15 @ May 30 2012, 08:00 PM) *
no no, I meant before you get used to the power and want more haha
autech_s15
Post #1658
oh yeah hahah defs
176OES
Post #1659
Tinted windows uleh!
Finally after 2yrs on the road with it I got rid of the bubbled tint that was on the back window... I can actually tell what car is behind me now... its awesome! :-D
Luke
Post #1660
Changed engine oil, diff oil, fuel filter and oil filter.
j.d.m
Post #1661
STD R33 Front Bar
will find a lip to suit/mould.
stevocharged
Post #1662
QUOTE (176OES @ May 30 2012, 11:55 PM) *
lol I should do the same with mine.
OT: General service and sh!t done. Still need another ignition module to test my misfiring issues.
autech_s15
Post #1663
funking lol.
spun a bottom end bearing
Aarie
Post #1664
QUOTE (autech_s15 @ May 30 2012, 09:00 PM) *
QUOTE (autech_s15 @ May 31 2012, 09:53 PM) *
funking lol.
Man that sucks arse. Sorry to hear it.
rolla boi
Post #1665
Doing rust repairs on the old girl. From this to this
autech_s15
Post #1666
QUOTE (Aarie @ May 31 2012, 09:17 PM) *
hah, wasn't at my fault though!
autech_s15
Post #1667
my car sounds like a funking VL turbo HAHAHAHAH
https://www.facebook.com/photo.php?v=325212434221405
Post #1668
Built a 2.5" catback for the daily (was cheap and for the lols), ducted the intercooler and radiator, cut my factory rear spoiler down to suit the new mounts for the AW11.
ShanO`
Post #1669
Gave the skyline a service before my upcoming track day on thursday.
Also installed a set of Defi's, only the boost gauge works for the moment. Need a couple of adapters before I can install the senders for the other 2 gauges.
_Ben
Post #1670
Checked the fluids, gave it a degrease. Still need to get a coilpack sleep.gif
wolfman101
Post #1671
Got angry, because some ass-hat dented my door.
Zimma
Post #1672
Drove it 25 minutes in uniform for a "meeting" found out the meeting was actually just to pick up a funking envelope to hand back in, drove off fuming and found out it is actually possible to spin the wheels in a rav4... Learn something new everyday.
Oh and drove it home 25 minutes or so while i hope not getting speeding tickets...
Post #1673
Started organising ECU reflash.
j.d.m
Post #1674
Oh and bought some metal polish; to give the rad and piping a bit of a make over. Sick of the watermarks everytime i open the bonnet.
Luke
Post #1675
New boot struts. Much better.
VersionR
Post #1676
Just fitted a HID kit, having dinner then refitting turbo kit, giggidy smile.gif
autech_s15
Post #1677
Got the engine ready to be pulled out next weekend.
Spun a big end bearing while it was on the dyno due to previous problems so now I'm rebuilding with forged bottom end. Plans are as follows:
SPOOL Forged H Beam Conrods
CP Forged Pistons (Rings, Pins and Locks Included) 8.5:1
Cometic MLS Head Gasket (1.8mm)
ACL Race Series Main Bearings - STD & 0.25mm
ACL Race Series Big End Bearings - STD & 0.25mm
Block bored, honed, decked an acid dipped
Head decked
GTIR Oil Pump
Timing chain replacement kit
ARP head studs
Nissan OEM main studs
Replacement OEM rear main seal
HKS stage 2 cams, 264in 272ex 11.5mm lift
HKS Cam Gears
Valves springs and retainers
Will be aiming for the 400hp mark with a td06
stevocharged
Post #1678
Fixed timing, and put some new front speakers in then cleaned the car inside long over due.
DAL32
Post #1679
Test fit new wheels. Well, wheel. The car can't be moved (clutch slave gone) so could only really put one or two on. Yes the tyre is a bit flat, I took it off after in the end.
autech_s15
Post #1680
Are they genuine te37s or those Vork Ravs?
Page 48 of 66
28 User(s) are reading this topic (28 Guests and 0 Anonymous Users)
