Turbo Go Kart - can u turbo a gokart
sigmagsr
  • sigmagsr
Post #1 post 14th February 2005 - 12:20 AM
just wondering if u could turbo a gokart and how u would go about it. wat size turbo would u use for a 250cc bike engine
big929
u will need a really small one, Honda city turbo'd r tiny and they are 4 times bigger than ur motor.
what engine is it exactly?
sigmagsr
im just asking in theory. i have no idea im just looking at doing a go kart project. and just tossing around a couple of ideas
Mr_Sleepy
everyone seems to toss around with this project idea, i should build some!!
i would suggest a healty 4 stroke motor of the 250cc size and a garrett GT12 turbo..
woody
some guy turbo'd a beer keg im sure u can do it to a go kart. maybe the turbo off a suzuki capacino
Jusdrifn 86
why turbo a go kart?
http://www.cobraclub.com/cobragallery/data...gixxerkart1.wmv
watch that video, you dont think he has enough power?
big929
is the kart for off road or onroad?
i had 2 off road ones, one a honda oddysey and the other was a 'home made' 5spd 125cc twin cylinder 2stroke with powerband, yummy!
won't cornering be a bit hard cause if u hit boost in a kart, it wont be like a car will it?
sigmagsr
that video is nuts thats wat i want. can u tell me wat engine was in that cause u dont need a turbo if its like that.
MoonLight
You would need a fairly small turbo, and probably a four stroke motor to begin with, if that isn't what you already have. Most two stroke motorcycle engines use "reed valves" to control the induction of air and fuel into the motor, and I'm unsure on how well these tiny plastic valves will hold up to even a few pounds of boost. Also, u would end up with a very oily turbo, as a two stroke uses oil and fuel mixtures ignited together in the combustion chamber. It's a great idea though. Although a few of us have probably already tinkered with it... Good luck
Amokk
yeah the go cart from that vid is mad hehe
PIMPIN SOARER
yeah that go kart is crazy i would like to no what engine is in it. Also with putting a turbo on a 2stroke engine doest work to well you would need to change the valves from plastic to metal and you would only be able to run a few pounds of boost. plus im unsure on what sort of compression the run so you would have to look into that because i have been told that 4stroke motorbike engines run high compressions. but i could be wrong
JeT
I'm not too sure on this, but I have been told you cant forcefully induct a 2 stroke engine?
Robinator
as for turbo...i suggest using an IHI unit off a 3cyl charade
fester
Don't know how to do it but you must be able to turbo a 2 stroke. Overseas there are some 2 stroke diesels and as far as I know they are still turbo'd, but we are talking some serious truck technology here.
you can get special ceramic reed valves which would stand up a bit better. Soem 2 strokes also ran a rotary disk valve???
Smoky60Sleeka
It probably wouldn't work too well because the intake gases, being at a higher pressure than the exhaust gases would flow out of the exhaust port before it closes, because in a 2 stroke engine the exhaust port opens, then the intake port, then the intake port closes before the exhaust port.
And the turbo wouldn't get all oily if it used a blow-through setup. Would it matter anyway?
fester
The engine is either a GSXR 1100 or a Kawasaki of similar vintage. eg 4 cylinder, twin cam road bike.
Phat535
a mate and I are almost finished building a home made off road buggy
it was running a 250cc 4 stroke motor and a very dodgy swivel type front steering setup, this time round it's a 500cc motor, 6 spd sequential gearbox and a steering rack/box setup from a gemini and motorbike disc brakes
we tossed around the idea of turbo'ing it too, but in the end just decided to go for the bigger engine
we wanna start a new one from scratch and use an R1 motor next time if we come accross a crashed one for the right price smile.gif
hi_lux
i am currently doing this to a 400cc 4 stroke engine. You will encounter problems with cooling and lubricating the turbo. I am looking at an IHI and a garret gt12.
black86
ofcorse u can turbo any conbustion engine intake and exhaust as long as u have enough power from the engine to spool the turbo ect
black86
in that video that thing has a huge amount of power But I tinks that this guy mabey just a show poney and wants a TURBO go kart tongue.gif
jimbo
the suzuki capacino is a tiny motor but at 900cc the turbo is probably still too big?
Crabs
A standard gearbox race kart holds the lap record and the fastest top speed at mount Panarama in bathurst...top speed 320kmh.
that is a 125cc race kart that you could pick up an sick but little bit older one for $3500.... when you ass is less than an inch off the ground and you can do 320kmh...you have to ask your self 2 questions
1. do I really want to be siting on a home made kart at 320kmh
2. do I really need a turbo
I think you know the answer
its nutts
2 strokes dont have an oil feed for a turbo which mean sur turbo would last about 5 minutes! unless u could set up somke sort of external container which pumps pil into ur turbo and then cycles it back to ur container. i know of a mate that put a turbo on a scooter and only got 2psi out of it and didnt really feel strong
MoonLight
I know some TRUCKS are two stroke turbocharged diesels but they probably have a totally different design than a 250cc moto engine. If you replaced the reeds, then maybe, but as someone said, you could get unburnt gasses flowing out your exhaust
deva
the engine on the gixxxerkart is a mini engine 1100cc.
personally i think u'd be best off with a small 2stroke non turbo, they still fukn cain.
also if u only wanted the turbo for the psssccchht factor, just buy a shitty little 4 stroke engine and turbo it.
depends on what you want really.
personally i'd be looking 4 a 2nd hand racing 2stroke cart, the good body is what your really after, u can always do engine work, but good engineering on the frame is VITAL!
57ING
Would a Nissan T-2 off a ET or Exa be to big?
Damone
i love that gixxercart video.
Phat535
QUOTE(deva @ Feb 15 2005, 03:40 PM)
[right][snapback]4967192[/snapback][/right]
actually it's a GSXR engine
hence the reason they called it the gixxxerkart
psi999
big motor would be the way, turbo would make it too fast
The Pupat
I'd look for a 600cc or 1000cc super sports (R6, GSX-R, et al) motor and gearbox from a wreck. Much easier and will work a lot better than a turbo'd 250.
Phonic
Just get a V-twin motor off a Harley, it'll be the V8 for karts heheh, doen't rev much, but has torque and sounds like a beast tongue.gif
DZ
Forced induction system works in the priciple of presurising the combustion chamber. This works well in a 4 stroke engine simply because they have seperate intake strokes and exaust strokes. During the intake stroke only the inlet valve is opened and the exuast valve is close. Where presurising the combustion chamber is possible.
However if you look at 2 stroke engines, the intake and exaust strokes are the same stroke, meaning the exaust port and intake port are open at the same time. Exuast takes place when the inlet gas (with fuel and air) forces the burnt gases out. Meaning, there is no point in forcing fuel/air into the chamber. The forced fuel and air will just exit at the exaust port, thus the chamber is not presurised at all.
GSRBOY
Just go for the high powered road bike motor. Anything around the 600 mark and over would be nice and wouldnt have the hassle of setting up the turbo. Still go real fast!
The Pupat
QUOTE(CyberTech @ Feb 17 2005, 01:25 PM)
[right][snapback]4971093[/snapback][/right]
Not neccessarily.
The turbo just won't be as efficient. You also get a gain in that the system will push all the exhaust out of the cumbustion chamber which is a problem with 2-Strokes.
You can also run the turbo by greasing it instead of oil.
Sockz
Deva (and others)- I'm pretty sure the gixxer cart is powered by a suzuki gsxr bike motor... Hence the name (GSXR's are nicknamed Gixxers).
I hope that's been covered somewhere in this thread allready.
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
