Post ![]() ![]() |
I'm after a 2wd Toyota Hilux 3RZ to install my turbo kit to. I manufacture turbo manifolds and full bolt on turbo kits under the name Quick Spool. The Quick Spool turbo manifolds are extremely high quality, come with a 3 year warranty and are used on various big name race cars including 'OKE020' Toyota Corolla which recently ran 8.4 @ 174mph. By changing to the Quick Spool manifold his turbo spooled up quicker as well as making more top end power. Before the manifold change previous best was 168mph. I am making full bolt on turbo kits for the 3RZ Hilux and have already fitted one to a 4wd. I am now wanting to fit one to the 2wd so make sure everything clears so I can then make up the full kits which will be available off the shelf. As a few of you would probably know these motors are amazing and they're producing some massive figures in the USA (1200+ hp from a 4 cylinder!) What I need is a Hilux for approximately 5 days to be dropped off at Cleveland Exhaust & Performance (Brisbane Bayside). The time estimate is for the basic setup, obviously if you want a lot of additional work done its going to take longer. At a minimum I am wanting to supply and install: - Turbo manifold; - Plenum; - Full 3 inch exhaust system; - Intercooler and intercooler pipes. I don't mind if you supply all other parts or if you'd like me to supply and fit everything. I can also organise for a full tune as well. The manifold is made from mild steel steam pipe with a merge collector and fully tig welded. It comes with a 3 year warranty against any manufacturing defects or the like. The plenum is custom designed so that it is forward facing which will eliminate the big 180 degree bend in the intercooler piping as well as reduce lag and make more power. I don't mind if you want stainless or mild steel pipe work. That is up to you but will obviously determine what you're going to pay for pipes. I will supply the following: - Quick Spool turbo manifold; - Quick Spool aluminium custom plenum with 80mm throttle body; - Master Power turbo up to T76; - 50mm wastegate. Normal pricing is over $3,000 but in this ONE OFF OFFER my price will be $2,400 or $1,300 for manifold and plenum only. We can work out pricing on all the pipe work etc (have to let me know if you want stainless or mild steel) but the full kit will be extremely well priced. I'm ready to go now with the manifold, the plenum will be welded up next week. So I would like to install this kit ASAP so that I can then offer it off the shelf to customers. This is first in best dress case. This offer won't be repeated and is a once off to the first suitable person only, solely for the purpose of making sure everything clears in the engine bay, like steering etc before the kits are offered off the shelf. The vehicle MUST be standard ride height and be available ASAP. Feel free to PM me, email will [at] expressparts.com.au or call / msg me on 0401 53 53 05. I'll be available during the Easter break if you'd like to discuss. Cheers Will ![]() ![]() ![]() ![]() -------------------- |
Express_Parts
hey mate do u need to do anything to bring the compression down or anything like that is the hilux motor got good compression?? No you can run it with the standard compression and it will be fine. Its all about how good the tune is. If you keep standard compression, rather than lowering it, it will bring the turbo on sooner as well. |
Express_Parts
For some reference iam running 320hp and 17psi in my hilux , never opened the engine up at all. Strong engines and go nicely with a gt35 on em BOT> Care to share what ya plennum looks like I'll get some photos of the plenum up in the next few days, just need to weld it up. |
