benno.h
Post #759
hey all Excel Drivers, SWAY BARS i have been in chats with jeff about the bars we can use as i already went out and got mine i have a nice new 18mm on the rear but was told by whiteline they only made a 22mm solid to replace the orig 22mm hollow front bar which they no longer make due to lack of sales(bad timing for them), and jeff is talking about staying with 18mm on the fronts as well, but i think there would not be any benifit, not that i think a supplier will make anything less than a 22mm sports bar, we need to know what others think and know about Excel front sway bar and do you want 22mm front solids or search for 18mm bars or stick with the standard. Dave Dunno why you'd even bother upgrading the front sway. A 22mm solid bar is just going to make it understeer. Having finally given ours a good flogging on decent tyres over the weekend, it's surprisingly neutral at the limit and we're not in any real hurry to get a RSB. |
trackattack
Post #760
Who do I contact to arrange for purchasing and fitting at QR. Have the day off on Tuesday so could do it then To buy Talons go here - http://www.trackattack.com.au/talon takes about 3 days to get them into stock RE the fuel cell. I would prefer to not modify the existing fuel system unless its a safety upgrade. I thought you were trying to keep the budget in check, fuel cells wont be cheap. |
nodrog
Post #761
To buy Talons go here - http://www.trackattack.com.au/talon takes about 3 days to get them into stock RE the fuel cell. I would prefer to not modify the existing fuel system unless its a safety upgrade. I thought you were trying to keep the budget in check, fuel cells wont be cheap. The reason I asked about the fuel cell is that I might be able to get a few ally cells made to fit in the spare wheel area!!! But happy to keep the original tank. |
trackattack
Post #763
The reason I asked about the fuel cell is that I might be able to get a few ally cells made to fit in the spare wheel area!!! But happy to keep the original tank. If you fit the fuel tank inside the cabin you will need to have fire separation between the tank and the driver. not worth the hassle. |
trackattack
Post #765
If I can get mine sorted good enough to be safe I will bring it up, otherwise its the datsun. |
X3man
Post #767
FYI |
NISMOgemini
Post #768
Also available Compomotive 6 spoke wheels |
X3man
Post #771
Yeah +35's not so bad in a 6.5" |
trackattack
Post #772
Also available Compomotive 6 spoke wheels 15x8 + 10 offset - $150.00 each, waiting on confirmation on the PCD are these available in 4x100 aswell?? Yes I can get them in 100 PCD, I think they come as a dual fit, just waiting on confirmation. |
zorak
Post #774
You could have made it, standard silvia's Who play's with excels? well when the market comes to terms that paying through the nose for something thats worth as much as a hyundai excel they will be an abundance of cheap silvias/180s to go around and make a race series of.... I think people are missing the point of this, a race series that will cost you less than 2k to run in and will show who can drive and who cant... if I wasnt moving to Melb Id be all over this like a rash. Well done guys, for the ones who get into it will be a heap of fun |
trackattack
Post #775
any pics of what they look like?? could be keen on a set for my gemini I am waiting on full spec, but I think its the M05 (either that or the M06) Offsets Available: et00 & et25>32 3, 4 or 5 Stud Fitments (Rallyraid Spec) |
trackattack
Post #776
I have 2 x spring packages available. |
benno.h
Post #777
I have 2 x spring packages available. Kings Low Package - $340.00 * Front Springs KHFL-114 x 2 * Rear Springs KHFL-124 x 2 or our Track Attack Special Pack that we are running on our car - $440.00 (The spring codes are a secret....shhhh) What spring rates for the Track Attack specials? |
trackattack
Post #780
LOL..... just call me "Race Mart" |
trackattack
Post #781
I have 6 spots left if anybody is keen for a Track Day at Carnell this Easter Saturday |
trackattack
Post #782
OK OK OK |
X3man
Post #783
Trackattack, talk to Chris Tarrent at King Springs they will make custom springs for $170 a pair. |
slow bus
Post #784
I want royalities, another great idea of mine light car with heavy car springs. Jeff had given a big clue what they come off it has to be common is commodore. and if you get the ultra lows you can drop it on its nuts |
trackattack
Post #787
At this stage I wouldn't envisage any major changes. |
trackattack
Post #789
i live 6hrs north of you guys so i was only really going to d the events at lakeside and qld raceway, i cant wait to have a go, t looks like heeps of fun tho it seems to be getting quiet serious never the less i cant wait are there any permanent race tracks up your way ? I am currently hunting for tracks within a days drive to try to make a bit of a series out of. |
NISMOgemini
Post #790
ill take a set of them bolts if you can get them I want royalities, another great idea of mine light car with heavy car springs. Jeff had given a big clue what they come off it has to be common is commodore. and if you get the ultra lows you can drop it on its nuts
Now I have shared alignment setting, whats the go? Iam thinking As much camber and caster as you can muster( minimum 3 on the front but 5 would be better) I have got 2.5 from stock equipment I will run camber bolts in both top and bottom hole on the front, should get close to the 5) 3degree toe out front 2 degree toe out rear (is this possable) I am waiting on my camber bolts from the US, if they are all good I will be able to supply a set of 4 for $50 |
