Vehicle Modifications - The Basic Handbook for Modifiers
Page 3 of 3
mikejoel
Post #71
cool guide
angelawright328
Post #72
Great job!! keep it up!
cambo1992
Post #73
QUOTE (Rookie ROX @ Oct 19 2009, 05:44 PM) *
Note that I'll start compiling some more guides around other FAQs relating to such things as P plate laws, penalties for infringements etc.
If you have any questions regarding VEHICLE MODIFICATIONS ONLY, please feel free to ask them in here. When I find the time to finish the others, you can ask those questions there. I will be keeping this thread clean and devoid of irrelevant information. If your post disappears, this is why.
This thread will be a master thread, so if your topic is closed and it's asking questions answered here, that's why. If you ask a question, ENSURE YOU NOTE YOUR LOCATION. As I've said multiple times, rules and regulations change State to State. We cannot give you an accurate answer if you don't mention it (or it's not in your profile), and we don't want to tell you one thing when it's different to where you are.
ROCK ON
hey i was interested to know if i could put a sliding window into my 05 rodeo and would it be legal and if so do you know where i could get one please
R~R
SUB81
Post #74
love your work!! thanks
sallycooper296
Post #75
It truly is excellent to own the prospect to undergo an excellent large good quality report with useful information on topics that loads have an interest on. I concur together with your conclusions and can eagerly look ahead in your long lasting updates. Thanks an excellent offer and maintain on submitting added helpful details.
mikejoel
Post #76
great article mate, thanks
stevenlee
Post #77
Very good write up, I'm sure this thread will be viewed by a lot of people.
Ticc
Post #78
QUOTE (351clevocorty @ Dec 26 2009, 07:28 AM) *
Integrity of the bonnet must be maintained, This is done by additional bracing should you need to cut into an existing brace. However the technicality there is the proof that the structural integrity has been maintained so an over zealous officer may ask you to prove that and the only way to do that is to have it tested which goes into the $$$ ie: These carbon fibre bonnets I see getting around can anybody confirm if they come with an ADR approval for the particular model & make of car that they are fitted to??
im pretty sure the only company that makes adr approved bonnets is blitz and the rest are a defect waiting to happen
pvk308
Post #79
I thought the only way to have legal fibre glass or carbon fibre bonnets was to have the original sheet metal bracing moulded into them. I remember a manufatcurer saying this when i was looking at fibreglass bonnet bootlid and gaurds for the vk
mikejoel
Post #80
synergy
Post #81
are traction bars, ladders bars legal on 4wds?
like dis
pvk308
Post #82
any thing that didnt come from the factory on the car is going to need an engineer to llok at it and maybe a tag becuase it comes under the suspension modification part of the DOT book
figjam00
Post #83
QUOTE (Rookie ROX @ Oct 19 2009, 05:31 PM) *
So after answering the same questions over and over, I have developed a guide for all of the most common modifications, and the legalities that apply.
what does the code LB 10--- mean on a mod plate
The Handbook for Common Modifications
  • Aftermarket Wheels
  • Lowering
  • Exhausts
  • Pod Filters
  • Steering Wheels
  • Lighting
  • Complex Modifications
  • Local Guides
We all know that when owning a car, we all want to add a personalised touch. For some it’s simply adding seat covers, some fluffy dice and an air freshener, for others it’s a little more involved, be it adding aftermarket wheels and a body kit, to souping up the performance of the engine. When carrying it modifications however, it’s important to understand the rules and regulations that govern what you can and can’t do to your car. By making sure your vehicle complies with your local rules and regulations, it will save your time, hip pocket and in some cases, a court hearing, from defect notices.
It is important to know that these are only summaries on the legalities, and in most only applies specifically to cars. There are differences in laws between cars (or car derivatives), off-road passenger vehicles, or commercial vehicles. They also use the specific laws of QLD, however courtesy of the framework for Australian Road Rules, Australian Design Rules and National Code of Practice for Light Vehicle Construction and Modification, for most parts they are similar across the country. If instances where there are differences, these have been noted, particularly for NSW and VIC. For those outside those States, sorry, but that's what happens when you live in the least populated areas! So let us begin;
Aftermarket Wheels
QLD - Maximum wheel size – Rolling diameter cannot increase more than 15+mm/-26mm
NSW and VIC - Maximum wheel size – Rolling diameter cannot increase more than 15+mm/-15mm
It’s no secret that most car manufacturers look for functionality and low cost when they put wheels on cars. They’re designed to go round and round, and not add style, so the most common modification performed is adding aftermarket wheels. With such a huge variety of wheels available, it’s important that the rim and tyre choice you make is the correct one.
Now to make sure you make the legal choice of rim and tyre combination, you need to know the stock combination. If your car still has standard wheels fitted, you can simply look at the tyre and find the size written on. If not, your car should have a tyre placard fitted, this is usually on the inside of the driver’s door, or inside the glove box. You’re looking for a number combination of ###/##/##, for example, 195/60/R14.
To continue further, you need an understanding of what the numbers and letter mean. As a brief summary;
14 denotes the rim diameter measured using the imperial system (i.e. 14”).
195 is the section width. It indicates the width of the tyre at it’s widest point in millimetres (mm)
60 is the aspect ratio. It indicates the profile (or tyre wall height) as a percentage of the width, so 60% of 195 equals a tyre wall height of 117mm.
R stands for radial construction. It’s not of much importance as most tyres are constructed this way.
V is the speed rating of the tyre. Different types of tyres have different speed ratings (maximum speed they can safely support).
Finally 87 is the load rating index. It’s a numerical code associated with the maximum load a tyre can carry.
The final figure you need to know is the overall rolling diameter. This can be calculated using the following;
RD = 2 x (60% of 195) + 14” x 25.4mm
RD = 234 + 355.6
RD = 589.6mm
Alternatively, you can simply use a good tyre calculator such as http://www.alloywheels.com/tyrecalc.asp
For more specific information you can visit http://www.carbibles.com/tyre_bible.html
So now we know what everything means, we can look at the legalities.
To start with, contrary to common belief, there is NO such thing as the 2” rule (i.e. Cannot have rims more than 2” over stock size).
The law works by looking at the rolling diameter, and nothing else. It states that you cannot increase the rolling diameter by more than 15mm than stock, or decrease the rolling diameter by more than 26mm, otherwise referred to as +15mm/-26mm. This means you can put as big sized rims as you want, provided you can find tyres thin enough. Ultimately, the closest rolling diameter you can get to the stock figure the better.
Changes in rolling diameter actually have an adverse affect on your speedometer. Increase the RD, and your speedo reads lower than you’re actually travelling. Decrease the RD, and your speedo reads higher than you’re actually travelling. This means you can be speeding without knowing it, and you’ll have to wear the fine if you get caught.
A decent tyre calculator (http://www.alloywheels.com/tyrecalc.asp) can help you figure out the best tyre size. A tyre shop should also have a book that gives options for tyre sizes and can assist you in making the right choice.
It is also important to note several other restrictions regarding wheels. Firstly, each axle must be fitted with the same tyre and wheel size, including rolling diameter, width and offset. Secondly, you cannot increase wheel width by more than 1.3 times the manufacturer’s widest optional tyre. Thirdly, tyres must have a minimum tread depth of 1.5mm on any part of the tyre that touches the ground, although it’s recommended to replace tyres prior to reaching this depth. For tyres, they must meet or exceed the load rating listed on the tyre placard, as should the speed rating.
Note that it is ILLEGAL to replace light truck tyres fitted by the manufacturer with a passenger tyre (unless the tyre placard states otherwise). Passenger tyres do not have the correct load rating capacities to meet the loads the vehicle can carry as stated by the manufacturer. This includes most 2WD utilities/utes.
Lowering
Legal Minimum Height – 100mm
Remove no more than 1/3 of suspension travel
Following new wheels, many people move onto lowering their vehicle height. It is important to know that a vehicle must be at least 100mm of the ground, measured from the lowest point on the vehicle (usually the exhaust or a body kit). It’s important to know that this figure should be measured when the vehicle is fully loaded. That means with passengers, luggage and a full tank of fuel. Therefore it’s not recommended to attempt to get your vehicle height as close to 100mm as possible, because as soon as you load up your friends, you’re likely to drop below that limit. Further, you cannot remove or reduce more than one third (1/3) of the working travel of the suspension from its original height.
Exhausts
Maximum dB limit – 90db (or 96dB pre-1982)
Changing the exhaust on a vehicle is also popular. However there are technicalities that can make legality an issue. Generally, the decibel level of an exhaust cannot be more than 90db measured 0.5-0.55m from the exhaust at a 45 degree angle on deceleration from a certain RPM. For vehicles manufactured before 1982, the maximum decibel level is 96db. This is where the technicalities start; altering the exhaust is classed as modifying a silencing device from manufacturer specifications. It is possible to be defected simply for this, even if you are under the limit. However, a sound level test is all that’s required to certify that your altered exhaust still complies with the specifications by proving it still reads under the limit. Attitude is the most likely determinant factor as to whether this is an issue. Aside from noise levels, exhausts must also comply with emissions standards. If a car is manufactured after February 1986, it must have a catalytic converter fitted. This also applies to vehicles with an engine manufactured after this date. Failure to have a cat fitted can result in a hefty fine from the EPA.
Pod Filters
Properly secured and attached to the car body.
NSW ONLY - Pod filters must be fully enclosed
Another common modification is the removal of stock air box from a car’s air intake and replacing it with a pod filter. There’s lots of misconception regarding the legalities of pod filters. It is legal to replace an air box and panel filter provided the filter is properly attached. This means a proper stainless steel clamp (not zip ties) and a metal piece connecting the filter to the body of the car. It should be noted that in NSW, it’s a requirement for pod filters to be completely enclosed in a box as well as properly secured. However it’s recommended to enclose or shield the filter from the engine bay anyway to prevent the intake sucking in hot engine air.
Steering Wheels
Not smaller than 350mm
It’s no secret that after several years, factory steering wheels can get quite worn and dated, and replacing them with new sportier versions is common. However, once again, certain limitations apply. A steering wheel cannot be reduced by more than 25mm from the factory steering wheel size but must not be less than 350mm*. If a steering wheel is fitted with an airbag, it cannot be replaced or removed with an aftermarket steering wheel. Finally, every car must have a working horn, so having a horn button is also a requirement.
Lighting
Using foglights when the weather is clear is an offence! Turn them off fogwits!
Adding extra lights or neon’s can bring more attention to your car, but it’s not always wanted. The fitting of under body lights (neon’s or LEDs) or other lights is legal, provided they meet several criteria. For under body lights, they cannot be distracting to other driver’s, this means you cannot see the source of the light. Flashing lights (excluding indicators) are illegal except for emergency vehicles or special vehicles in hazardous situations (usually amber lights on construction vehicles, tow trucks etc). Note the law specifically states that you cannot have lights that 'dazzle'. It is at the discretion of a police officer as to what they believe is distracting or dazzling. Like many police encounters, a poor attitude is likely to change their interpretation of the law.
Colours are also limited. Blue lights cannot be fitted to any vehicle at any time, unless it an emergency vehicle – this includes under body lights, LED washers. parkers or interior neons visible outside the car. White lights can only be visible from the front of the vehicle; red lights can only be visible from the rear of the vehicle. Purple cannot be used due to their use by the Department of Transport. Yellow (or amber) should only be used as clearance markers.
Consult your State's road authority and/or an Approved Person before carrying out these modifications
There are some modifications that require specific approval by engineers or ‘Approved Persons’ and the fitting of a modification plate (blue plate in Queensland, engineering certificate in NSW etc). These can include the fitting of aftermarket seats, particular engine conversions, turbocharging or supercharging, brake conversions, major suspension changes, the list goes on.
A full list of the different modification codes and can be viewed here - http://www.roadsmart.com.au/docs/NCOPApprovalCodes.pdf
The National Code of Practice for Light Vehicle Construction and Modification has been put in place to create uniform standards through Australia and has been tentatively adopted by each State and Territory. Each NCOP document has information highlighting specifications and requirements for modification approval. However, before considering making any complex modifications, it is important to consult an engineer or Approved Person first to confirm the requirements and specific legalities of each State, as due to the voluntary adoption, there are still minor differences between jurisdictions. For full specifications, visit http://www.infrastructure.gov.au/roads/saf...n/vsb_ncop.aspx
It will also be important to know that despite having a national set of guidelines, no State or Territory will recognise the modification approval of another State/Territory. This means if you purchase a vehicle from, or move interstate, you will need to get any and all modification approvals done again in the State/Territory you intend to register the vehicle.
For QLD - The Queensland Transport Modification Hotline is your godsend. They have access to the database that lists every Approved Person in the State, and what they can approve (remembering that some are limited into what they can approve). If you attempt to ring the general QT enquiry number, or speak to someone in person, you won't get anywhere. Call (07) 3253 4851 and you will receive the information you need. To make life easier, tell them the Approval Code you need so they can ensure they give you the details of the right person.
Local Guides
As noted earlier, despite a national framework, there are still minor differences in the rules and regulations. The roads authorities for each State and Territory have developed booklets that outline guidelines (similar to this document) that you can use as a quick reference. They are all available from the relevant authority's website, and are as follows;
QLD - http://www.transport.qld.gov.au/resources/...r_vehicles2.pdf
NSW - http://www.rta.nsw.gov.au/registration/dow...ns_nov_2007.pdf
VIC - http://www.vicroads.vic.gov.au/NR/rdonlyre...8340/0/VSI8.pdf
SA - http://www.transport.sa.gov.au/personal_tr...ht_vehicles.asp
WA - http://www.transport.wa.gov.au/licensing/1412.asp
Disclaimer
This document should only be used as a guide and cannot be used as a legal document in a court of law. It should not be treated as any form of legal advice.
Prior to modifications, check local regulations to confirm requirements.
Roadsmart will not be held liable for inaccuracies, jurisdictional differences or changes to laws. This publication was correct as at October 2009.
http://www.roadsmart.com.au/laws/licensing...ions/index.html
ROCK ON
R~R
quickr32
Post #84
Thanks. some good information there
Catapult
Post #85
I work for vicroads so if any one has any vic related questions I'm happy to help
Page 3 of 3
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
