6th May 2009 - 03:59 PM
Post |
hey all just wondering how do u install a turbo smart stage 2 bov, being a twin turbo i don't know where to install it and if i need 2 ??? any help would be great |
pipster11
is it auto or manual? |
Pocket_snail
its a auto unfort but still goes hard. the car stalls the first time i start it nd when i start it again its ok its got me confused |
35NIK
i would be wary about putting an atmosperic bov on the auto tends to make them stall so something (not 100% sure tho) My auto runs fine on a atmo bov, with tiptronic you do have to let off the throttle between gear changes to vent the load. And yes it does run rich on gear changes, just a little pop from the exhaust every nown & again. I did try to plumb mine back, But it was been gay & would not open whenever I plumbed it back, so i left it at atmo. It runs better with the stock bov, but the stock one leaks boost badly, so I would rather hold full boost pressure & let it run a little bit rich. |
mongrel_cae71
My auto runs fine on a atmo bov, with tiptronic you do have to let off the throttle between gear changes to vent the load. And yes it does run rich on gear changes, just a little pop from the exhaust every nown & again. I did try to plumb mine back, But it was been gay & would not open whenever I plumbed it back, so i left it at atmo. It runs better with the stock bov, but the stock one leaks boost badly, so I would rather hold full boost pressure & let it run a little bit rich. lol @ lifting throttle on gear changes on a tiptronic. you don't like your transmission do you. |
35NIK
lol @ lifting throttle on gear changes on a tiptronic. you don't like your transmission do you. i dont really, But 3 years ago, it was hard pickings finding a manual R34. Anyways... letting off is the only way to stop it from bogging down inbetween gears when you run a atmo bov in a auto. if you dont let it vent It will try & push air back in when the turbo is trying to push out again for the next gear under load. Stock bov is back on my car again after tonight on the gold coast mt, the bogging down gave me the shits. |
Pocket_snail
my misses forester i put a turbosmart stage 2 on it nd drove wit it on for bout 6 mths nd it never stalled she tells me ??? |
