brind0g
Post #106
Well technically his MX5 is a bullet, as he has a completly built this car from the ground up... like you said, the only original thing on the car is the doors, and the boot... Has RX7 Suspension/Brakes, custom built chassis, custom 1 piece fibreglass bonnet... But now its getting a LS2 V8!! haha |
323
Post #108
QUOTE(sl8 @ Mar 2 2009, 10:43 AM) [snapback]1283663336[/snapback] Are you kidding? You are mate saying. Haha and your telling some one how to use proper grammer. Grammar wars 2.0. By the way it's "grammar" Not "grammer" ![]() OT: Nice 180 mate, she has turned out really well, keep up with the good work. ![]() |
sl8
Post #112
QUOTE(Marcus89 @ Mar 2 2009, 11:52 AM) [snapback]1283663368[/snapback] you fail. He is saying that your should have been used instead of you're which means you are No i belive i do not fail You fail. He is trying to say, You are mate is saying that blah blah is correct. How the f*ck is that correct? |
brind0g
Post #114
I go tno idea what ur on about sl8, but lay off the waccy tabaccy... it aint doin u any favours... |
EUniqe
Post #115
dont all speedos work that way though? maybe not on the wheel tho, drivetrain or sumten. if the speedo magnet is on one wheel, it will be inaccurate when you are turning because the wheel you put it on will spin at a different speed to the wheel on the other side of the car and will not necessarily be the forward speed of the actual car. |
brind0g
Post #116
Not all speedos work this way... |
brind0g
Post #117
Well I have finally sorted my Speedo issue, still need to get it calibrated and make sure its accurate, but im using a Vapor Speedo/Computer off a Honda CRF250... |
Marcus89
Post #119
QUOTE(wooley @ Jan 30 2009, 01:19 PM) [snapback]1283501063[/snapback] nice english u tell everyone to type properlly it's your not you're(you are) QUOTE(sl8 @ Mar 2 2009, 12:30 PM) [snapback]1283663849[/snapback] No i belive i do not fail You fail. He is trying to say, You are mate is saying that blah blah is correct. How the f*ck is that correct? See that not means that's the one he is saying is incorrect/the one that should be used sorry for bringing that from the grave haha people ![]() Definitely an awesome build should hammer along nicely |
Commander
Post #125
top end = cams and cams = expensive... make sure no more than 10psi cause anything over that and the factory gaskets start complaining, so i got cometic metal ones in case i go that way |
