Shuff's General Chat Thread ... #73 - Talk about anything and everything...
Page 26 of 487
vk134
Post #876
don't forget the simple fix sometimes the MB battery , mostly they are CR2032, worth a $5 try, I've had it fix countless, clusterfk bios startup glitches
Doc
Post #877
unpluged hdds.. still same.
every time i start up it goes straight to launch system repair/ start windows normally. when i start normal it just
goes black screen,, if i do repair goes to the crappy win7 blue flowerery screen and stays there..
wolfman101
Post #878
That's borlz. In other news, just flashed my TCU. Plugged in the portable OBD2 unit I got in the mail, waited til it beeped....now apparently my shifts will be 30% faster. Ah, technology.
Doc
Post #879
QUOTE (vk134 @ Jan 16 2014, 10:00 PM) *
thought of that before... cannot find for life of me where its located
on this thing...
just dont understand why this has happend. was fine last night, didnt install any hardware or
software... very frustrating..
QUOTE (wolfman101 @ Jan 16 2014, 10:13 PM) *
just like that....
alpharx7
Post #880
QUOTE (Doc @ Jan 16 2014, 10:07 PM) *
only replug in your boot drive - this is something that my brother suggested, he's had a similar problem caused by a windows update I believe.
looks like you may be doing a fresh system install doc, good chance to pull the computer apart and clean all the dust out.
I hope you didn't lose anything.
Doc
Post #881
cbf doing anymore tonight.. to late.
cant even do a factory restore, wont give me that option when i go for system repair..
will lose a little bit, but not much, pretty much everything is on my external hdd. i did manage to run
diagnostics with the utilities dics.. did find an error in one of the sata drives, said to write down the number
and give it to tech if problem persists..
thanks for the tips...
vk134
Post #882
It is great isn't it, but I guess the 30% gain will come at a cost of drivetrain wear and strain. It does shit me when the aftermarket tuners etc all bag the factory setting and get great gains and pat themselves on the back, when the factory drivetrain engineers are hamstrung by emissions, NVH and durability issues.
A classic was the XR6 turbo, at the end of the testing and all tests passed with a very soft tuned engine 240kw as the V8 boss at 260kw was to be the flagship as well as the torque would blow the T5z. They were green lighted to test to destruction the mule engines, I think they all easily managed the 300 to 310kw, then the limit of conrods and valve spring longevity was reached, but they had peaked one at 342kw before it lunched itself.
I am sure the situation is the same all across the world, I only knew of the BA when trying to sort out the POS brakes and driveline issues when they were new.
vk134
Post #883
QUOTE (Doc @ Jan 16 2014, 11:51 PM) *
a tip to decluster updates, system restore then disable updates
Doc
Post #884
QUOTE (vk134 @ Jan 17 2014, 08:59 AM) *
Can't even get into to do that that, won't boot up, won't boot in safe mode, won't do system repair when try that,
Post #885
QUOTE (Doc @ Jan 17 2014, 11:17 AM) *
The Wife's laptop had a similar problem a while back,Doc,and it ended up being a corrupt pathway,took a trip to the shop to fix it unfortunately,but she didn't lose anything
.Tim.
Post #886
Had a similar problem recently. HDD was fuxored. it happened in almost identical fashion to what you are mentioning
Doc
Post #887
Have a pc shop here at work, will as if they do repairs
Doc
Post #888
Yer he says it's a fuxored hdd, will fix it for me tomorrow,
Post #889
That's convenient Doc,so will you lose anything?
Doc
Post #890
Yer I'll lose a lot of stuff, but nothing that is irreplaceable, most of the files are on an external
wolfman101
Post #891
Hehehe looks like I have tiny wheels.
vk134
Post #892
looks like you parked at Logan, lol, but the safety stands instead of besser blocks give it away
fearlesss
Post #893
QUOTE (Doc @ Jan 17 2014, 03:50 PM) *
Sorry why are you loosing anything ? It's pretty rare that a hd would be completely rooted.
is the BIOS picking up the drive ?
Just buy a new drive, install windows, copy everything from the old drive to the new one..
Going from the symptoms it sounds like you just have a few corrupt sectors where some of your windows files are located...
It'll take your 1-2hrs and cost like $70 for a drive
Doc
Post #894
Thanks for the tip fearless,
Was looking at my external earlier, pretty much a lot more in there then thought, so not losing much at all, just a few programs and crap with I'll get back,
Managed to get into the reinstall set up, after all other options failed, so far its 39% and counting, so if all goes well seems as though hdd is fine.
Doc
Post #895
What the f'king fcuk!!
Just went to turn on my little netbook which I was using last night to copy some settings, now that f'king thing is black screen with NTLDR is missing..
alpharx7
Post #896
^^^^ kill it with a stick.
Doc
Post #897
Ill put it under a a tyre... That will fix it
alpharx7
Post #898
reminds me of what we used to do with front wheel drive cars and macca's trays. mamoru.gif
Doc
Post #899
Still won't boot, Mr PC guy can fixit
QUOTE (wolfman101 @ Jan 17 2014, 04:12 PM) *
What's going on here?
vk134
Post #900
QUOTE (alpharx7 @ Jan 17 2014, 09:47 PM) *
Nooo, surely it deserves a late night mega reformat against a traffic sign at 160 km/h (closed roads, top gear style of course)
wolfman101
Post #901
QUOTE (Doc @ Jan 17 2014, 11:00 PM) *
Wheel refinishing. I will be replacing the discs all around next week too.
Doc
Post #902
You been spending big time the last few weeks lol
Zemorning
wolfman101
Post #903
Yeah...I have actually managed to overspend my credit card for the first time ever surprisingly. Never thought I would.
Doc
Post #904
Just zero it and start again lol
wolfman101
Post #905
Not an issue-it just auto-debits, I've never not paid it off in full. Just weird to see an overspend on the statement.
VashBandicoot
Post #906
I'll just leave this here
Tweak
Post #907
its a tarp
Post #908
LOL!Doc will be banging on his computer man's door,saying 'hurry up and fix my 'puter,I need to download something' mamoru.gif
Eugene Dickins
Post #909
Oh Hai!
Post #910
QUOTE (Eugene Dickins @ Jan 18 2014, 02:32 PM) *
Oh Hai!
Page 26 of 487
