Big Turbo And Smaller Turbo Power
vk_of_death
  • vk_of_death
  • Budding User
Post #1 post 9th December 2003 - 05:26 AM
If i had a big turbo and a smaller turbo on exactly identical engines and they were both running exactly 10 pounds would the engines make the same power.
All you keyboard warriors are just pissed off that the bully used to take your chicken sundwich from you at school..
And yes i am aware i dont know how to use full stops commas or proper grammer.
Monaro getting turboed 2nd time lucky for the v8 turbo recipe
Amokk
nope
the bigger turbo would flow more air so therefor make more hp
but the power curves would be very different
vk_of_death
Yeah the big turbo wouldnt have to spin as hard to make the 10 pounds but the amount of air being pushed in is the same
woody
no the big turbo would flow more air. would have much better top end. the small turbo would flow less air but have better low to mid range power
Amokk
no.. i meant the volume of air
so the bigger turbo would be pushing more air
look at it like this
if u had a 2m pipe and a 10m pipe
and pushed water through them @ 10psi
obviously the 10m pipe would push more water through
so its the same with turbo's
the bigger, the more air it pushed at each psi, which will give u the hp
but obviously there are downside to this
ie lag and so on
woody
thats right, hence the different HP ratings for turbos
vk_of_death
Oh alright so boost level has nothing to do with the volume of air going in
S15_Clint
boost pressure is just the flow rate of the air, the volume however changes, as others have stated.
Pie
im confused now but i think i get it!
Boost pressure is proportional to the airflow. But 10psi is just max boost, the turbos have to work over a whole range of rpm and boost pressures.
It all depends on the actual size of the turbo to begin with, The is too many factors to say a larger one will flow more than a smaller one.
You need to take into account compressor wheels and internal flow rates.
_______________________________________________________________
Amokk Stated
ie lag and so on
This may be correct if you increase the size of the intake But putting a larger turbo on an already restricted intake would have a negative affect to the power curve.
SHERIF
i had a gsr once and went from the standard turbo to a t28bb
the t28 ran 2psi less and made 50kw at the treads more
and it came on quicker and harder
but then i went bigger again and it made even more power but had to wait days for the lag to get ova
JJRB30ET
it also depends WHEN this boost is reached..bigger turbo needs more exhaust flow to produce the same pressure level, hence higher RPM..higher RPM for the same torque = higher power.
180GO
