2008 Ford Falcon - QLD: Brisbane
zade
  • zade
Post #1 post 8th November 2013 - 04:23 PM
2008 Fg xr6t dash green 30,000kms
Zf 6 speed auto
It's my daily on a safe 320rwkw with 900nmt on bp98 still on standard turbo
Here's wat I've done
Intercooler process west stage 2
Flash tune with 3 custom tunes
Xr8 lower air box n Snorkle with KnN
12 pound actuator
Hi flow 100 cell 5inch cat
Advanced 4 inch dump pipe
3.5inch custom Exhuast with 4 dump tip
Injectors 1000cc
Fuel pump Bosch 044
Earls oil fed turbo line
Heavy duty harmonic balancer
Atomic flex plate
Atomic valve springs
Atomic oil pump with gears
Atomic crank gear
Atomic timing chain
Ported waste gate n 38mm flapper
Belved domed flex plate washers
New big end bearings
Harder spicer tail shaft
Standard 18s powered coated gloss black
Pwr transmission cooler braided lines
Xyx coil overs in the rear
Ssl King springs in the front
Boge shorted shocks
Tinted windows
Carbon wrapped roof strips n mirrors
Turbo smart 25mm dual port compact bov
Alloy Dress up kit
Led tail lights
Slotted n dimpled rotors bendiex pads
Gauges oil,boost and water temp autometer
Tuned by profile Autosports
All other work carried out by my dad at top gun automotive
Diff will be getn done on Monday then il take it to the drags to give it a run
Future mods
Gtx 3582r or Fg f6 turbo
Eatons tru trac diff
Process west Muffler delete kit
Remove rear spoiler n get it welded in n painted professionally
Xr8 bonnet painted dash green
Process west Surge tank
Will easily see 400rwkw on bp98
2008 Ford Falcon
2008 Ford Falcon
2008 Ford Falcon
2008 Ford Falcon
2008 Ford Falcon
2008 Ford Falcon
  • Boost Network 15
  • Faun-
    sweet car... terrible photos
    zade
    Cheers, sorry bout the shit photos they went all small
    ash20990
    Nice car! Just a little advice when you get to it, it's much easier to get a rear boot of a base model instead of welding it up. I did it to my bf when I had it.
    zade
    benrz88
    nice car Clint is a pro at tuning your in good hands
    zade
    Bradza
    im not much of a ford fan but this is nice
    zade
    Thanks
    DECOY
    Looks the goods mate!! 320kw's with all those mods though seems really conservative... Its has the potential to make sooooo much more its not funny.
    zade
    Thanks mate,ive still got stock turbo cud push it to 350rwkw wudnt last long at all tho till the turbo shit it self, got more torque, got a few mods as I blew oil pump gears up went thru the housing n made a good mess
    zade
    zade
    Bit of a update still got 320rwkw on standard turbo
    Took it out to the drags a few times best of 12.3 @ 116mph on street tyres 245
    Gunna get some street ets and go out again
    Fitted Eatons tru trac diff centre
    Xr8 bonnet
    Got spoiler removed and holes welded in
    Process west muffler delete
    Got a process west dual entry fuel rail and turbo smart reg with speedflow fitting n hoses to go on next week for a e85 tune
    zade
    zade
    zade
