How To Get Flex Out Of A Hilux
Atrovato
  • Atrovato
  • New User
Post #1 post 23rd April 2011 - 04:02 PM
Hey guys im going to start building up a 4x4 its a 89 hilux xtra cab.. leaf front and rear.. just wandering how much i could lift it and how to get a decent amount of flex out of it . as most hiluxs i have seen are very rigid and have next to no flex at all.. its already got a 4 iinch lift but im prosuming thats its going to be very rigid and i want it kinda high just for the extra under carrage clearance but also what it soft for flex . is that possible with leafs ? some tips would be great as im only newish to 4x4 and seeking some advice.
Cheers Aaron
project toneski
go back to standed leafs and get the lift you want with extended shackles and big tyres, disconnect the swaybars
Fatboyz inc
it will all depend on the spring rate i.e. how much weight they are rated for and if they are suited to what you want to do I had 4" Blue Max leafs and shocks on mine rated as medium duty so I could carry my bike or quad when required and got plenty of flex with or without the bike/s on. the info you are after would be better sorced on outerlimits4x4.com or similar 4wd web site but here is a few pic's of the flex from my 4" lift with 33"procomp Exterains.
Atrovato
cheers bud smile.gif so id preferably need softer springs ? is it neceserily the the springs ? or just how many are in the pack?
OPE114
Getting a hilux to flex is this simple...
Rear springs and banana shackles in the front
IFS rears and 200mm shackles in the rear.
If you don't mind the odd defect, get shock hoops for the front and an inboard kit for the rear.
Add some bilstein shocks and you will have all the flex you could ever want or need!
For all of the above, you should see change out of $1200.
Atrovato
not worried about defects as its not going to be registered thinking of macking it comp truck
but cheers man will definitly look into it
Fatboyz inc
if you want to turn it into a comp truck I'd be looking at surf rear with coil set up and solid axle coil front as well you should be able to pick a whole one off fleabay for under a grand and what you dont need sell on and make your coin back, you will always get more flex from the coils but if you are going to stay leaf then I'd go the drop shackles or air set up ect as OPE114 sugested.
Atrovato
yer i would prefere coils but as my first comp truck i might leave it leaf and see how it goes from there aye. i figured im gonna do a hilux cause everyone up here is running patrols and landcuisers so i figured why not do something ya dont see very much of
cheers for the advice man
OPE114
If you really want to go all out mate, use the same springs and shocks as I said, just add drop shackles!
Coils are great, but for the money you will spend getting them
in and to work properly, they aren't worth it!
Spend the extra cash on front and rear air lockers, and you will pretty much be unstoppable!!
Atrovato
yer sounds the way too go mate . im definitly gonna put an airlocker in the front.. it has an lsd in the rear so if i get it tightned that should be enough for the rear or is a locker still a better option yet? im budgiting about $8G for all accesories excluding tyres we will see how i go ... ill post a pic as soon as i have it in my driveway smile.gif
OUTLAWS
Call Buddy at Buds Customs 0417 708 598 he is the hilux man...
OPE114
Twin air lockers would be ideal mate, but if the budget can only fit one, get the front done as you said.
As Outlaw said, bubs' knows hilux's better then anyone.
I would get your shackles, shocks, shock hoops, inboard rear kit thru him.
Springs you can get from pretty much any wrecker.
The older and saggier the better in my opinion.
You want to keep you car as low as possible. Jacked up lux's are notorius for laying over due to there narrow wheel base.
Silver Surfer
QUOTE (OUTLAWS @ Apr 24 2011, 09:57 PM) *
tonkalux85
i got a compleate coil front for sale out of an 80 series all the stering racks and panard rod disk to disk if u want to coil convert the front of your lux 300$
Atrovato
yer will defs give him a call mate cheers for his number ... yer i dont really wanna lift it much just a tiny.. just for the xtra ground clearace.. but i guess big tyres can do that wink.gif ha
cheers for all the advice guys. pretty keen to get stuck in will deffs post some pics up
Thinking of doing an engine conversion aswell kinda leaning towards a 186 motor or maybe a 202 or maybe something injected like a commo v6 if any ones had any experience or has any pionters were ya can buy kits from and what not would be great
Atrovato
Have just been advised that its IFS soo im not that keen any more. wen i went and had a look at it .. it was the only thing i didnt sus out is IFS anygood ? or should i keep searching ?
Atrovato
this coil setup u have mate is it as simple as it seems ?
OPE114
Shameless plug, but save yourself the time and effort and just buy mine mate. Lol
Atrovato
hahaha its sick but im trading my old ute for a fourby dont wanna fork out money haha
lynchy
modify ur leaf packs and get some drop shackles longer shocks thats a start anyway did u want to keep it legal?
