21st November 2010 - 01:20 AM
Ok so i have inherited a 95 model MJ triton, dual cab. It has a 2.5L 4D56T Turbo diesel, runs leaf spring live axle rear and torsion bar IFS. Not great for offroad, more for load carrying i guess, but hey its what i got and it was a free truck so im gonna run with it for a while. The truck sits pretty high as it was a roo hunting vehicle - rear has some heavy duty springs to cope with weight of a few roos etc. Made the back sit fairly high, so ive rotated the front torsion bars to bring the front up to the same height. Gives ok clearance. Im going to run a set of pajero wheels or sunraysias and some 31" AT tyres - wont be seeing a lot of mud. . MY QUESTIONS ARE - Is it worth running a boost controller to up the boost pressure? Im not sure what they run standard, or what they can cope with. The engine has done 166,000 and doesnt miss a beat. Well looked after vehicle service wise etc. Is there a benefit with running a small top/front mount intercooler, on either standard or increased boost? Is there a benefit with running a larger diameter exhaust, and an aftermarket air filter such as a K&N? Are there any other basic modifications i can do to increase power output or ground clearance? Looking underneath the truck, it seems like a body lift would be a fairly simple mod if i were to run 1" milled spacers and a longer bolt or whatever it is that mounts the cab to the chassis. Is it as simple as it looks? I dont want to be extending wiring or brake lines etc, but an extra inch would help a lot with tyre clearance. . Im well aware of the benefits the engine/exhaust modifications have on petrol engines, but am not sure how well diesel motors react to the same modifications. Thanks Guys -------------------- Helping smart-arses look like dumb-arses since August '85
Me on TripleJ and smashin it! 72 Ford Galaxie (557 stroker in build) 73 XB Falcon (351/toploader/9") 80 CM Chrysler (265/4spd) 94 XG Falcon Ute (4.0/5spd) 93 EB Fairmont (302/BTR) WANTED: poor condition 2nd hand alloy wheels and tyres. Want some alloys repaired and refinished? PM me |
DJE06
exhaust for sure probably 2.5 inch turbo back. you can increase the boost a couple of psi but y ou gotta be careful how far you go. you wont need a body lift if your running 31s. Not alot you can do about ground clearance except run 33s in which case you may need a body lift. and be careful how far youve wound your torsion bars up cuz they change your cv angle and if the angle is to high youll more than likely snap them on a regular basis |
lil_bobby_260
exhaust for sure probably 2.5 inch turbo back. you can increase the boost a couple of psi but y ou gotta be careful how far you go. you wont need a body lift if your running 31s. Not alot you can do about ground clearance except run 33s in which case you may need a body lift. and be careful how far youve wound your torsion bars up cuz they change your cv angle and if the angle is to high youll more than likely snap them on a regular basis Ok so ill look at getting an exhaust done then. Im going to fit a boost guage just to see what its running at, and maybe just increase it by 15-20%. Ive wound the torsion bars up to the point where the front sits level with the rear - it did have some hot rod style rake going on. Ill double check the CV angle to make sure its not too full on. I was thinking a body lift as there isnt a huge amount of clearance between guard and tyre even with stockos on it. No thoughts on the intercooler? I have one here i can use, is why i was thinking of doing it, and can do the pipework myself. |
Silver Surfer
QUOTE Is it worth running a boost controller to up the boost pressure? Im not sure what they run standard, or what they can cope with. The engine has done 166,000 and doesnt miss a beat. Well looked after vehicle service wise etc. Personally I wouldn't waste your money here QUOTE Is there a benefit with running a small top/front mount intercooler, on either standard or increased boost? Standard cooler will be fine. QUOTE Is there a benefit with running a larger diameter exhaust, and an aftermarket air filter such as a K&N? Go a 2.5" QUOTE Are there any other basic modifications i can do to increase power output or ground clearance? Power you could get a power chip, as for ground clearance if you have already wound your torsion bars up and there is lift in the back you could go a body lift but that will only give your body more clearance and allow you to run bigger wheels, bigger wheels is the only way to lift the diff. QUOTE Looking underneath the truck, it seems like a body lift would be a fairly simple mod if i were to run 1" milled spacers and a longer bolt or whatever it is that mounts the cab to the chassis. Is it as simple as it looks? I dont want to be extending wiring or brake lines etc, but an extra inch would help a lot with tyre clearance. Most places sell a 2" or 3" body lift, depending on the car you may need brake extensions, need to remove the lower part of the radiator shroud/lower radiator. you may also and most probably need to cut out the floor pan around the gear stick. |
lil_bobby_260
Cheers silver surfer for the info. |
lil_bobby_260
Reminds me, if anyone in the brissy/northside area has a set of wheels/tyres that are more capable off-road than my monster 205's on 16x6" rims, let me know what youve got and what you'd want for them! |
lil_bobby_260
lil_bobby_260
25 or so in total? |
frenchman
Nice truck! |
lil_bobby_260
Im lead to believe the effort required to fit a boost controller is... all of about 5 minutes? Not a lot of effort. I wouldve thought that a boost lift would be more noticeable than just fitting a cooler, and that the cooler really would just be a good supporting mod for a higher boost, to bring the inlet temps back down to standard. |
Big_Black_Pontiac
the only real way to find out if any of the engine improvement stuff works is to actually do it, so go for it. if ur gonna drive it around a lot as in daily driver ide keep a set of standard wheels for that only bolt on the big ones if ur gonna go out 4x4ing. when i put my big tyres on it fucked my fuel economy so i put my standard alloys back on untill i need 2 actually use them. |
lil_bobby_260
Hmm thats not a bad idea BBP, and will save wearing out big rubber too. |
siksuzi
Personally I wouldn't waste your money here Standard cooler will be fine. Go a 2.5" Power you could get a power chip, as for ground clearance if you have already wound your torsion bars up and there is lift in the back you could go a body lift but that will only give your body more clearance and allow you to run bigger wheels, bigger wheels is the only way to lift the diff. Most places sell a 2" or 3" body lift, depending on the car you may need brake extensions, need to remove the lower part of the radiator shroud/lower radiator. you may also and most probably need to cut out the floor pan around the gear stick. ahahahahahahahahahahah yeah, chip it its a mechanical fuel pump, not a modern DiD motor OP do yourself a favour, sign up to outers or the pajero club of victoria for info regarding power upgrades, lift etc |
lil_bobby_260
Yeah shes very basic engine wise. Not very bloody high tech! |
lil_bobby_260
lil_bobby_260
Raised the bullbar on its brackets (plates and new holes) to suit the body lift. Is completely reversable too - can remove the body lift and drop the bullbar in an hour or less if necessary. |
Big_Black_Pontiac
looks the goods now. u should whack it up on the members rides, i just put my triton there. no doubt someone will find something to bag out about it tho lol |
lil_bobby_260
Haha yeah i just posted in your members rides topic actually. I think im a fair bit better at physics, mathematics, and COMMON SENSE than about 99% of those on this site. |
Big_Black_Pontiac
yeah i saw that! i can see both sides and theres always gonna be difference of opinions no matter what but like i said it does what i want it to do so far, i didnt have 2 spend thousands on a suspension lift which u cant get anyways |
lil_bobby_260
lil_bobby_260
I know man they were ridiculous... The 2" body lift and fitting of 31's is the best modification ive done to it as far as improving the trucks ability goes. I think it should be just about any 4wd'ers first step. Cheap, and huge performance gain. |
lil_bobby_260
lil_bobby_260
lil_bobby_260
Any tips? umm... no not really man, but feel free to PM me if you have any questions or need more detailed information. |
minirobbie
mate had one of these used it as a chase car in off road buggy racing , defo get a body lift they need it , 33s fit great when you do. be carful increasing the boost .. i did it gave me alot better top end i also had a pajero top mount intercooler tho on mine with a small fan on it, for when the going was slow, but watch your manifold gaskets , they have a bad habit of blowing the gasket around number 1 cylinder and also the little one that has the 2 bolts in it on the outlet of the turbo, the factory wastegate isnt real happy with too much extra boost and i have been told to use a turbo off a 2.8l td as they are better and from wat they said a straight forward fit. |
minirobbie
Any tips? umm... no not really man, but feel free to PM me if you have any questions or need more detailed information. I had actually looked into running the factory flare kit like your triton has but too expensive to buy, and i kinda like the look of the flexi-flares. Only other real mods on my list are drop shackles, an exhaust system, and water/methanol injection. if you want flares get hold of a just 4x4s mag there is a guy there that advertises flare kits for them in fiberglass i think from memory was $440 a set i cant remeber mite have been cheaper . .bloody nice flare kit too |
lil_bobby_260
minirobbie its got a 2" body lift in it, and they are 32" MT's on it and even with the torsion bars up fairly high they still scrub occasionally. I have doubts about 33" tyres. |
