Turbo Shaft Play Question - Brand new turbo
DreamensioN
  • DreamensioN
  • ITS FUN
  • Contributing Member!
Post #1 post 27th January 2005 - 11:22 PM
Hey guys,
Just wondering - in a brand new turbo - is there meant to be a little bit of play? When I say a little - I'm talking like 1-2mm max! Or is the shaft meant to be rock solid and you can't move it (laterally) at all?
Just trying to work out if it's a dodgy turbo or if this is perfectly normal.
Need free trance albums? Get them @ DreamensioN .NET
Tracks: http://soundcloud.com/dreamension
Doin' it for the love of dance music....
SkiDMaN
2mm is quite a fair bit.. if u can move the shaft and it touches the housing or there are scratchy marks on the housing... then yer... it wont last too long
Pete
Fixxxer
My new Garrett T04R turbo here has no shaft play, in and out and side to side.
Fixxxer
BoostedS15
A teeeeeeeeeeeeeny tiny bit of *side to side* shaft play (less than 1mm) is acceptable.............ANY *front to back* shaftplay is NOT acceptable.
SupraCrazy
If it's a new turbo & it's got shaft play....take it back & claim warranty.
Chucky
Doesn't sound too good. 2mm in any direction is like puting your wheel nuts on the first 2 threads.
IF your looking to buy, don't, unless its stupidly cheep. If you have, sorry, i hope you didn't pay much
any turbo should have shaft play, when the engine is off the oil passage is dry that would normal lubricate the shaft / core, hence why it moves slightly
QUOTE (TwinCam16 @ Jan 31 2005, 07:08 AM)
yes, i agree... most garrett turbos use oil to self-centre the shaft, so a very small amount of movement is evident when the oil is not filling the space around the shaft.. but we are talking between 1mm and less. If the shaft is rock solid and wont move even the slightest bit, then it is probably jammed.
Just check that the shaft will not move in or out (end float) because that is BAD.. check the housing near the comp wheel for scratches and have the wastegate pressurised if you can, to see that it works properly.
its nutts
mate every turbo i have either bought brand new or had it rebuilt and always there was about 1mm play sise to side but never in and out. because i wondered the same thing at first and my mate who works for volvo assurees me its ok
psi999
What turbo have you got, any specs?
Use the following as a guide (Garrett BB)
Maximum shaft end play (thrust) (back and forth) should be 0.20 mm (play should NOT be noticeable using your fingertips) while shaft radial play should be no more than 0.56 mm (very noticeable sideways movement using your fingertips).
Try putting some oil in it and see if the movement is decreased if it’s outside of tolerances.
tripharn
It isn't one of the those dodgy turbos that are going around.
XS or something similiar?
Sleeka_89
QUOTE(psi999 @ Feb 1 2005, 04:27 PM)
[right][snapback]4940034[/snapback][/right]
With or without oil, for a brand spanking new turbo to have any play is wrong ohmy.gif , return it before u even bolt it to save da hassel taking it out again and also so the ppl that u got it from know it hasnt been used. I've just bought a Gt-4 half cut thats done a tad over 100k on it and its turbo still has no shaft play....yet laugh.gif
MoonLight
Yeah mate, it shud be ok. If it's oil cooled and lubricated core, than there shud be a bit of play cause thee is no oil in there obviously
