Where Is The Standard Boost Solenoid On A Rb25det? - iv got pics can yous tell me which one it is??
enzed_dk
  • enzed_dk
Post #1 post 25th July 2010 - 01:58 PM
im trying to earth the standard earth wire from the standard solenoid so that it runs on high boost,as i have researched that in the r33's they run on 5psi before 4500rpm then after that they change to 7-8psi..and if constantly earthed they run in high boost mode all the time..
but iv never had an rb25det before and dont even know where to find the boost solenoid..i think its one of the following ..
please take a look and tell me which one it is..
Akshunhiro
Pretty sure it's mounted on the passenger side strut tower near the power steering reservoir. Just look for a vac line from the wastegate actuator or turbo outlet housing.
EDIT:
^^ As above.
enzed_dk
thank you guys so much
enzed_dk
ok i dont have one of those .... there is the rubber hose that runs to where it should be but its capped off...the car still runs fine ect but should this be a problem??
Mongrel
r33 wastegate actuator is a 5psi unit, without the factory bleed valve, this is all your car is running, unless someone has installed a aftermarket gated bleed somewhere else.
pipster11
i suspect there is a boost t hiding away somewhere
