31st October 2016 - 06:11 PM
So there's something in your car not working and you think the fuse is blown? A common problem for Ford Falcon BF Owners unfortunately. It could be your indicators, hazard lights, door locks, wipers, instrument cluster, or most commonly cigarette outlet. Here's the digram, but remember, if you don't have a diagram you can always pull out each fuse, one by one and visually check it. You can usually pick a blown fuse by comparing it with a fuse that's known good - it's pretty obvious with the track going through being broken. -------------------- :: BoostCruising :: The Automotive enthusiasts site with extensive Car Sales, loads of Car Parts, mags, wheels and Tyre Sales, along with subs, tweeters, head units, speakers, heaps of Car Audio. Over a million Aussie's can't be wrong!
Twilightdiscos
So there's something in your car not working and you think the fuse is blown? A common problem for Ford Falcon BF Owners unfortunately. It could be your indicators, hazard lights, door locks, wipers, instrument cluster, or most commonly cigarette outlet. Here's the digram, but remember, if you don't have a diagram you can always pull out each fuse, one by one and visually check it. You can usually pick a blown fuse by comparing it with a fuse that's known good - it's pretty obvious with the track going through being broken. hi which book is this out off please |
scotty2hotty61
what is the most common cause for window washers not pumping water on 08 BF Falcon, removed hose off passenger side & tried but no go, sucked on the water line & water came through, do you think water pump, or is there a fuse i can't see? cheers |
