1983 Toyota Corolla CS KE70 - QLD: Brisbane
Faun-
  • Faun-
  • Regular User
Post #1 post 11th February 2013 - 07:55 AM
Gen 3 3sgte ke70 flat front
BODY
- 1983 beige flat front ke70
- guards are colour matched (not that well) with spray can beige.
- 'Panda' front headlight surounds
- spirit wing
-15x6.5 and 15x7 wheels (need to be 15’s to fit over brakes)
ENGINE & DRIVELINE
- gen 3 3sgte (2.0L with high mount turbo manifold with splitpulse system)
-gen 2 sump a believe
- Rebuild t03
- Haltech e6x computer
- custom intake plenum
- custom engine mounts
- front mount intercooler
- Hilux running gear (w56 gearbox, shortened tailshaft, hilux diff)(non lsd) 5 speed
- external wastegate plumbed back to exhaust
- super sequential BOV
- custom plenm, v8 ford throtle body
- 3 inch turbo back exhaust with two hi-flow mufflers
- LS1 coilpacks
- bosch 044 fuel pump
- Freshly reconditioned clutch slave by repco services
SUSPENSION & BRAKES
- Ae86 front struts with soft springs and unknown shocks
- xt130 or ke55 lca not sure which but they are 300mm.
-unknown rear shocks with around 5kg springs
- v6 camry vented rotors and calipers front
- r31 r31 rotors and calipers rear
- Nissan r31 brake master cylinder
INTERIOR
- Standard and clean
- Hilux shifter
- aftermarket steering wheel
Not sure on power have wanted to get it dyno tuned for a while now.
1983 Toyota Corolla Cs Ke70
  • Boost Network 5
  • ITS2EZ
    shreksoarer
    hells yeah. i like!!
    The Doctor
    do like.
    a nice paint job would go down well
    alpharx7
    need moar granny spec, sunvisor, hat in rear parcel shelf, stockies, i luv lawn bowls sticker etc (hey you said to say something). tongue.gif
    nice little sleeper you have there faun.
    Zimma
    Needs more beige...
