Post
27th February 2007 - 12:20 PM
Specifications
EngineType: V10
Displacement cu in (cc): 303 (4961)
Power bhp (kW) at RPM: 530(388) / 8000
Torque lb-ft (Nm) at RPM: n.a.
Redline at RPM: n.a.
Brakes & TiresBrakes F/R: ABS, vented disc/vented disc
Tires F-R: 235/35 ZR19 - 295/30 ZR19
Driveline: All Wheel Drive
Exterior Dimensions & WeightLength × Width × Height in: 167.7 × 74.1 × 45.4
Weight lb (kg): 2997 (1360)
PerformanceAcceleration 0-62 mph s: 3.8
Top Speed mph (km/h): n.a.
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
Base Price: 2007 Lamborghini Gallardo Superleggera - n.a. (last update: 2/27/2007)
Gallardo Superleggera: Lighter and More Powerful
With the Gallardo Superleggera, Lamborghini presents an uncompromisingly high-performance sports car. Thanks to 10 additional horsepower and a 154 lbs weight reduction, the new range-leading Lamborghini Gallardo Superleggera offers even more excitement and driving pleasure.
The Superleggera also has the fastest acceleration in its class. It needs only 3.8 seconds to go from 0 to 62 mph; 0.2 seconds less than the basic model, and boasting speed and grit under other driving conditions.
The Lamborghini Gallardo Superleggera is an extremely high-performance car: it includes a standard robotized mechanical ‘e-gear’ gearbox that guarantees shifting without removing hands from the steering wheel. The car can be ordered through the dealer network starting March 2007. Production volumes will be restricted to lower numbers than the standard Gallardo.
More Horsepower
The Lamborghini Gallardo Superleggera’s engine is the latest version of Lamborghini’s well-known 4,961 ccm V10. The increase in power (to 530 bhp) was made possible by the engine’s improved volumetric efficiency through reduced intake load losses and by exhaust backpressures, together with optimized electronic control.
Advanced Technology Helps Reduce Weight
Lamborghini engineers decreased the Lamborghini Gallardo’s already low weight when empty by another 154 lbs using advanced materials and technologies. The engine hood is made of visible carbon fiber and transparent polycarbonate, a type of material that guarantees lightness and also shows off the magnificent V10. The rear diffuser and underbody covering, the rearview mirrors, door panels and the central tunnel’s covering are also made of carbon fiber. Further reductions in weight were achieved by replacing certain glass surfaces with transparent polycarbonate. For the interior, monocoque carbon fiber sports seats covered in Alcantara were chosen to ensure restraint of the driver and passenger during the intense lateral accelerations that the Gallardo Superleggera is capable of achieving around curves.
Exclusive Options
A comprehensive specification and extensive range of options will be available, with some exclusive to the Superleggera. The Superleggera comes with robotized mechanical e-gear as standard; a sports package including shock absorbers; and special suede-covered steering wheel. The car is available in four colors: Midas Yellow, Borealis Orange, Telesto Gray and Noctis Black. Pirelli P Zero Corsa tires (standard) on new Scorpius forged rims accentuate the Lamborghini Gallardo Superleggera. A few of the options that can be requested include the multimedia system with navigator and CD-changer; a rear video camera to make parking easier (with optional rear wing only); a Carbon accessories kit for the interior; a fixed rear spoiler; a four-point seatbelt (not for USA); tubular rear frame or fitting points for later inclusion (not for USA, Japan or Middle East); and carbon-ceramic brakes.
2007 Lamborghini Gallardo Superleggera Photo 1 of 0
