1st March 2009 - 07:54 PM
hey guys, i have a problem with my rb30, it runs fine when its cold, but when it warms up, it has a serious miss, has no power and when i accellerate it looses power and wants to stall, i have replaced the following: air flow netre cam angle sensor plugs leads coil cleaned out the injectors (profeesionally) fuel regulator intake pipe fuel pump fuel filter drained my fuel tank blew out all fuel lines got cracks in my exhaust welded up new catalystic converter new muffler box new o2 sensor cleaned out my air filter and its still doing it its driving me crazy -------------------- how do u know a mechanic has just had sex??
1 of his fingers are clean |
My thoughts are that if you have replaced all of that, check to see if the ECU has had water in it, which is common to leak in from the windscreen. |
TuffVC
I could wildly adjust the quality of idle on my R31 simply by moving the harness that went to the injectors,Im not talking about reefing on them,Im talking about wriggling it with my fingers!!! |
