Snorkels
Page 1 of 3
gotta_b_a_lux
QUOTE(HSV @ Apr 11 2009, 05:30 PM) [snapback]1283886523[/snapback]
Have you tried the Hilux wreckers down at Chinderah?
tried those wreckers, he said he hadn't had one in for 2 yrs an the one that came in was unusable due to roll over haha.
Try Ebay then champ, they pop up in there.
gotta_b_a_lux
QUOTE(HSV @ Apr 14 2009, 10:51 AM) [snapback]1283899980[/snapback]
decided to go full stainless here is what i have so far, i pick up the straight pipe tomoro. so far it has cost me $240 including the straight pipe. i can get it tigged an polished for $50 or the equivelant in piss. hsdance.gif
issues
Thats the go, mate
Mosus
i'd like to see how this turns out, was thinking of doing a simlair thing to mine good work so far
gotta_b_a_lux
QUOTE(Mosus @ Apr 14 2009, 08:18 PM) [snapback]1283903205[/snapback]
ill take pics as i go if i remember, i have to relocate my radio aerial first an fill the hole in. and i have a water trap in that guard so i will have to take that out too.
i have surgery next week so then i have 4 weeks off so i have plenty of time to do it.
im not 100% on how i want to attach it to my pillar yet, i was thinking of a bit of stainless angle welded to it with some clearance holes and a couple of short tek screws
MR_NATTY
i was to late. bout to say i would sell u the one of my lux, im going daul stainless
gotta_b_a_lux
QUOTE(MR_NATTY @ Apr 15 2009, 05:18 PM) [snapback]1283907896[/snapback]
bugger, throw up some pics of your stainless one when its on.
Still makes me giggle when you see these on a petrol motor.
living_low
stainless ones look so much better...
but do they heat up in the sun much at all??? causing the air to heat up?? probly not lol...
joshp7712
Try www.4wdsystems.com.au They're normally round the high $200 mark n come with a full set of diy instructions
gotta_b_a_lux
QUOTE(living_low @ Apr 15 2009, 06:14 PM) [snapback]1283908322[/snapback]
haha, can't be much worse than a black plastic one. should be cooler seeing its reflective...
gotta_b_a_lux
does anybody know where i can get one of these pre filter snorkel head beanies from?? besides 4wd systems in SA, pref somewhere in brisbane...
laynlow
redlands 4wd centre he stocks them i've seen them there! they are behind the counter usually
gotta_b_a_lux
QUOTE(laynlow @ Apr 16 2009, 04:10 PM) [snapback]1283913326[/snapback]
cheers, once its on ill call in an get one.
still waiting on the 3'' straight pipe to come in...
B Unit
QUOTE(MJ187 @ Apr 11 2009, 01:27 PM) [snapback]1283885404[/snapback]
Got that made for me at Nerang performance and 4x4. was $800 fully fitted and everything, didnt have to do a thing, thats also using 3.5" pipe, its much cheaper to use 3" pipe and i got more bends than needed because of the 80 series body shape, makes it a bit harder to bend around the mirror and keep it flush with the body, you wont have the same issues with a lux as they are very different and its much more simple, so it will be also cheaper for that and if u use 3" pipe which is enough for a lil luxy. also its only $150-200 more than it is to have a plastic one fitted so its not that much more for something special. =]
That looks great. Does anyone know where in Brisbane I can get one of these done? The bigger the diameter the better for me. I also have an 80 series, but with a turbo 6.5L V8 Chev engine, so the more airflow the better for me.
gotta_b_a_lux
QUOTE(B Unit @ Apr 16 2009, 06:55 PM) [snapback]1283914368[/snapback]
i spoke to this guy in neumann rd capalaba and he said he had done one on a cruiser before, full stainless, fitted, with a custom stainless air ram. he charges 65/hr, 55/hr cash
Brett
QUOTE(TwinCam16 @ Apr 15 2009, 07:07 PM) [snapback]1283908261[/snapback]
you're such a retard shane, do you really think petrol motors like water any more than a diesel?
smiley
QUOTE(Brett @ Apr 16 2009, 09:43 PM) [snapback]1283915521[/snapback]
My dizzy has a rubber glove pulled over it now with leads coming out the finger holes and zip ties everywhere... it's almost water tight. it really just means i can go through really big puddles... not swimming though.
dommie13
DIY Instructions Here
http://www.mudrhino.com.au/Docs/DIY3.pdf
gotta_b_a_lux
got my 3'' straight pipe an i got a new antenna for my radio. i have surgery tuesday so will prob start on it wednesday after i get out of hospital.
Cheap.
$50 +postage.
http://www.outerlimits4x4.com/phpBB2/ftopic171449.php
gotta_b_a_lux
got out of hospital this mornin so starting on my snorkel this arvo. gunna start with relocating my radio aerial, an just making sure where im putting the hole, etc
gotta_b_a_lux
got the old antenna out, not exactly reusable lol
any ideas for filling in the hole? was thinking a rubber grommet or sumthin instead of bog an paint.
ive got a new antenna, so im just gunna put it in the same spot on the other side.
tuff33
QUOTE(gotta_b_a_lux @ Apr 15 2009, 08:30 PM) [snapback]1283909250[/snapback]
http://cgi.ebay.com.au/Snorkel-Pre-Cleaner...A1%7C240%3A1318
here u go mate in brissie
gotta_b_a_lux
QUOTE(tuff33 @ Apr 22 2009, 09:08 PM) [snapback]1283945630[/snapback]
thanks mate
gotta_b_a_lux
i found a rubber grommet for $2 at clark rubber to fill the old antenna hole, i just sealed the bare metal around the hole with primer before i pushed it in. the snorkel should hide most of it. also bought a new 83mm hole saw, for the 90' stainless bend to sit in.
gotta_b_a_lux
marked out an cut the first hole for the snorkel this arvo i have to elongate the hole tomoro so that the 90 degree bend sits tight against the body.
than cut through the body, and primed all bare metal surfaces.
i had some help tho
just lost the winning bid. i was up with 10 secs to go. spewin haha
laynlow
are you going to have a ram head like you see on most plastic snorkels or put a 45 degree bend on the top facing the rear of the ute so as not to get dust and water in it?
gotta_b_a_lux
QUOTE(laynlow @ Apr 23 2009, 09:12 PM) [snapback]1283951725[/snapback]
plan is to use the plastic air ram i already have facing forward to help force air in when highway driving. then for when im wheeling i will spin the head around an put the pre-filter sock over the air ram head.
gotta_b_a_lux
used the angle grinder to shape the hole in the guard for the bend. used 250mm of flex with 2 good hose clamps and some rubber spacers to get the joins super tight, water tight (hopefully).
i just have to cut the straight pipe up an one of the bends an then it will be getting tigged early next week.
laynlow
looks great! nice and neat
smiley
How come you cut a hole into the engine bay and didnt use one of the existing holes there?
gotta_b_a_lux
QUOTE(smiley @ Apr 24 2009, 02:31 PM) [snapback]1283955691[/snapback]
mainly as they were in the wrong spot an no where near 3''
also got a pre-filter from redlands 4wd today
tuff33
nice job u done there mate
Page 1 of 3
