Breather On Catch Can An Rocker Covers - Whats the use?
Post Topic
razor-
Post #1 post 18th January 2008 - 08:56 PM
Hey.
Just wondering what the use of breathers on oil catch cans and rocker covers is?
Is it just for looks or does it have a purpose
I live my Life quarter mile at a time, for those 23 seconds nothing else matters
Rancher
Oil splashes around under the tapet cover. There is a breather that usually goes to the intake pipe, the oil will splash into the intake pipe, thus, the motor will burn it when it sucks it in.
Tapet covers need to breathe. It helps the oil flow from the top of the motor down. The catch can does exactly that, catches the oil that splashes up too far. The filter is to keep it breathing.
On most cars its not needed. On some turbo cars it is. On the LS1 its advised. But, if you have a 1993 toyota camry, its not needed. (That was just an example)
STR8E180
i put a breather on my catch can because i dont want the air going threw my intake system again
i dont like the idea of having oil passing threw my compressor housing again
bop001
wow that makes alot of sense man..
i was always told on sau that if i did that on my catch, it would lose its efficiency or some crap...i have the recirculating one..
would this be true?
STR8E180
if ur catch can is connected to the intake system it will have vaccum so u will be sucking air out of ur crank case
if u have a breather (filter) u will lose that crank case vaccum
i personally would rather have a clean compressor housing/ clean intercooler piping/ clean intercooler/ clean throttle body / clean plenum
STR8E180
just thought i would post up some pictures of my twin catch can setup
it isnt finished yet but here are some pictures of wat it looks like
Rancher
The recirculating ones are ok, because the catch can is still catching the air born oil, thus, the intake isn't sucking it it.
I don't believe its losing efficiency though, thats a load.
STR8E180
QUOTE(Rancher @ Jan 19 2008, 09:12 PM) [snapback]1281830844[/snapback]
argeed
razor-
Ok i still dont understand..
Could somebody lease draw up a diogram of where the lines to a catch can goes because i understand what it does (Catch oil thats to close to the intake or sum poo) But dont understand how it works.
If brathers are so important why arnt they on rocker covrs standard?
STR8E180
QUOTE(razor- @ Jan 20 2008, 01:57 PM) [snapback]1281832231[/snapback]
the reason why breathers dont come standard on rocker covers is because it will be venting str8 out which means its a defect
ive been defected for my breather on my catch can once already which is why im chaning my catch can setup to a twin catch can setup
razor-
Ok thanks i kinda get it.
But isnt yours in the picture breathing straight out aswell because of the 2 open holes??
When you say intake you mean air intake yer? If so why woud oil be going into there?
razor-
Ok so i just seen this picture and it kinda explained it to me..
Exept why do you need the breather there? Why dosent the catch can just have one hole for the pipe to go in and not another one for the brather or would all the gases just be to dangerous?
So if you have a catch can you dont have a breather on the rocker cover?
STR8E180
QUOTE(razor- @ Jan 20 2008, 05:27 PM) [snapback]1281833069[/snapback]
my 1st catch can had a filter which got me defected thats why i changed to a twin catch can setup
the 2 holes ur looking at arnt my breathers
remember how i said "it isnt finished yet?" when im finished with it every thing will be connected
the only reason it isnt finished yet is because ive got so many other cars i need to finished i cant just drop everything and work on my car
bop001
i know its on a skyline man. but its a turbo car and it gives a basic idea.
from memory this is for 100%, 50% and venting to atmo breather/catch cans.
http://www.skylinesaustralia.com/forums/Ca....html&st=20
blacky83
Losing "efficiency" is probably related to emissions. The idea behind the ventilation system is to stop the engine spewing out crappy gases to the atmosphere. Catch cans were to collect the oil in the vapours.
Breathers will increase your power efficiency, but increase the amount of emissions you'll make.
razor-
ok thanks.
1 Last Thing.
If you dont have a catch can how does the gasses get to your intake?
Or is that a way that some people set it up that makes it go to the intake?
STR8E180
QUOTE(razor- @ Jan 21 2008, 10:07 PM) [snapback]1281838657[/snapback]
ok thanks.
1 Last Thing.
some catch cans will be hooked up to ur intake pipe
razor-
Ok thanks..
If you dont have a cath can just a standard rocker cver without breather what would happen to the gasses/oil?
Also if you wanna fit a catch can do you have to cut a hole it it for the brather/ hoses for the catch can?
STR8E180
QUOTE(razor- @ Jan 22 2008, 12:55 PM) [snapback]1281840489[/snapback]
Ok thanks..
u have 2 options
option 1. have a filter on the catch can so it can breath <----- this is a defect
option 2. have it connected to the intake pipe so it breaths back into the intake system <---- not a defect
u cant not have a filter or not have it connected to the intake system because if it wont be able to breath at all ur going to build up to much pressure in the crank case and u will pop out ur dip stick and u might even pop out some seal's and cause a oil leak
razor-
ok so does a standard setup having the pressure going to the intake?
STR8E180
QUOTE(razor- @ Jan 22 2008, 02:00 PM) [snapback]1281840872[/snapback]
yes it does
razor-
Ok Thanks.
If i made a got a hose and put it on the can like in the picture would that make it road worthy?
Then once its road worthied just take the hose off and put a breather on
STR8E180
yes it would
u see the 2 outlets i havnt hooked up
im gonna put a little baby filter on them so its gonna look pretty nice (just need to buy the filters)
bop001
SO in a 'perfect' world, without the EPA and legal issues.
what would be the BEST performance and efficiency wise in regards to either the VTA or RECIRC cans?
razor-
QUOTE(STR8E180 @ Jan 22 2008, 09:41 PM) [snapback]1281842905[/snapback]
yes it would
But wouldnt having a filter on it be breathing to the tmosphere therefore making it unroadworthy?
Would putting the hose between them be dangerous for the motor ie. Becuase there would be so much pressure in the can it could "pop the dip stick and seals" like you said earlier Or would tht take a fair amunt of driving? More driving than just to get it registered
STR8E180
QUOTE(razor- @ Jan 23 2008, 02:59 PM) [snapback]1281845281[/snapback]
i dont realli give a shit about being unroadworthy any more the car isnt my daily any more
yes if u put the hose between them it could be dangerous because ur catch can doesnt have any form of breathing/venting
MR2Mark
QUOTE(blacky83 @ Jan 21 2008, 12:51 PM) [snapback]1281836355[/snapback]
A properly set up catch can will increase power slightly by reducing the amount of positive crank case pressure contaminants taken up into the intake as per stock hose-directly-to-intake type setup. The contaminants are a mix of mostly oil vapour and combustion gases that slipped past your piston rings as blow-by. All cars have some blow-by as explained below.
It also stops the crank case rubbish droplets hitting the turbo compressor blades at high speed (some believe possibly damaging the turbo or shortening its life) and prevents your intercooler and pipes filling up with oily residue.
Provided the catch can is recirculated back into the intake it will not increase emissions (apart from when you empty the catch can maybe) and it will be prefectly legal.
QUOTE(bop001 @ Jan 23 2008, 10:57 AM) [snapback]1281844329[/snapback]
A properly baffled catch can will remove almost all of the oil vapours from positive crank case pressure. Whether VTA or plumbed back into intake should make no noticable difference.
Finally an excellent quote from tristan on mr2oc
QUOTE(tristan @ January 24th, 2005, 14:41) [snapback]1281836355[/snapback]
Ebay catch cans - a warning
Im noticing a lot of people going out and buying ebay catch cans recently without realising how dangerous this can be for your motor so I thought I'd start this 'awareness' thread.
The oil breather on the cam cover is primarily there to vent crank case pressure which is caused by blow-by during combustion. Some people associate blow-by with tired engines but all engines have an element of blow-by, even brand new motors using gapless rings.. and especially turbo motors due to higher cylinder pressures. The idea is to keep blow-by to a minimum.
And the breather vents these gasses and prevents pressure buildup in the crank case.
Why is pressure build up bad? Well especially as far as turbo cars are concerned, crank case pressure if not vented will travel up the turbo's oil dump and eventually blow oil out of the turbo's oil seals.. this is one of the biggest causes of turbo oil seal failure.
So, why are the majority of ebay catch cans so bad? The internal diameter of the stock breather line is 14mm or more all the way through. I am seeing more and more cans pop up that have fittings that are around 4mm in diameter.
Do the maths.. thats 154mm sq of flow area compared to 12.5mm sq.
Only 8% of the flow capacity of the stock line!
Last night a customer brought his car to me. The motor had recently been rebuilt but after fitting a catch can, he complained of his dipstick popping out and oil spraying everywhere... I identified the catch can as the problem but did some other tests on the motor to make sure.
175psi compression across all four cylinders and very low blow-by.. it was a perfectly healthy, low km motor.
And yes, the catch can was an infamous ebay style job .. it had massive 20mm hoses but the fittings that screwed into the can only had an internal diameter of 4mm. No surprise the pressure was building up enough to pop the dipstick out.
Thankfully in many cases the dipstick is like a fuse for the turbo.. but in many other cases the dipstick doesn't budge and the turbo is the next thing to let go.
Other dangers include oil onto the exhaust or heat wrapping ... heating up and igniting... causing engine fires. It happens far too often.
So - you have been warned! Use decent gear and if you're already using one of these cans, look into having the holes drilled out for larger fittings. I would personally not in any situation run less than 10mm ID fittings and lines... with 14mm being recommended.
-Tristan
blacky83
A breather by definition will be venting directly to the atmosphere, so whatever way you have the catch can set up if it's got a breather it will technically be illegal.
For proper emissions setup, any vapour/etc must only exit an engine after being burnt in the combustion chamber, and passed through the catalytic converter in the exhaust. Hence all the ventilation setups and stuff.
Not telling you not to do it, just want to explain the whole story.
bop001
excellent quote mate. that pretty much answeres all the questions we needed to know.
great work.
i will probably go a vta one then. its mostly a drag/track car
razor-
Thanks for the help.
I now know what ill do
STR8E180
finished the catch can
MR2Mark
quite an elaborate bit of kit, but it looks pretty!
Laterz.
So many lines it would confuse a police officer/dot officer
STR8E180
QUOTE(Laterz. @ Jan 31 2008, 03:18 PM) [snapback]1281878111[/snapback]
yeah i know LOL ive been defected for my breathers on the catch can once already which is why i went with this design
the breathers vent into the air box smile.gif so all should be good now
Laterz.
If I was a police officer or DOT officer, I would deem that LEGAL.
Air filter sucks air thus the gas from the rocker cover is going back in......
..you can do the same with the BOV.
A mate has his HKS SSQ bov on his skyline facing to the pod filter... BOV vents, air goes to air filter.
  • razor-
  • Budding User
